Old 2nd Mar 2021, 1:10 pm   #1
Steve G4WCS
Steve G4WCS's Avatar
Default Yaesu FT290RM
Received my new radio today. How interesting. It had been described as having a mutek front end fitted which it was clear from the pictures it hadnt. Instead however its had a number of modififcations performed by A.R.E, which are listed on the leaflet that came with it. Havent had chance to try it out yet, but its extremely tidy for its age. I had put the cart before the horse and picked up a Mutek preamp, whilst looking for a radio. Ill list it for sale here as its surplus to requirements now.
Does anyone know the thickness of the battery pack foam, and where to source please ?
ID:	228046   Click image for larger version
ID:	228047   Click image for larger version
ID:	228048   Click image for larger version
ID:	228049   Click image for larger version
Steve G4WCS is offline
Old 2nd Mar 2021, 1:11 pm   #2
Steve G4WCS
Default Re: Yaesu FT290RM
Mutek preamp
ID:	228051   Click image for larger version
Old 2nd Mar 2021, 10:30 pm   #3
Steve G4WCS
Found various suppliers of foam on ebay. Had it on the comms test set today, its extremely sensitive and giving full output. Not checked the audio quality. Giving it a good clean and polish.
With its history, and condition its definitely a keeper
ID:	228123   Click image for larger version
ID:	228124   Click image for larger version
Old 6th Mar 2021, 9:57 pm   #4
Steve G4WCS
3mm neoprene foam sheet fitted. Ordered some high capacity NI-MH AA cells and AA-C adaptors. On air testing shows it to be quite lively
https://youtu.be/uSov3DGhBjY
I want to replace the ty-raps with some clear lacing cord though
ID:	228453   Click image for larger version
ID:	228454   Click image for larger version
Old 7th Mar 2021, 1:02 am   #5
mickm3for
Hi i am glad to see i am not the only one to use a beacon to do a quick test of a radios performance in my case GB3VHF on 144.430 in Trosley, great radio Mick Just noticed you are running this without its aerial this forms part of the final tuning and can result in a blown final transistor
mickm3for is offline
Old 7th Mar 2021, 1:34 pm   #6
Steve G4WCS
Thanks Mick yeah noted. Yes NGI is readily receiveable here. Can also pick up GB3VHF from up here in Lancashire when theres a slight lift on.
Old 11th Mar 2021, 9:07 pm   #7
Steve G4WCS
NiMh AA cells and adaptors fitted. Its cost less than a third of the price of C cells.
Its still on its original memory back up battery which fortunately hasnt leaked. Ordered a surface mounted coin cell holder to make future replacement easier.
Ive also cleaned the case, its come up very nicely
ID:	228930   Click image for larger version
ID:	228931   Click image for larger version
Old 11th Mar 2021, 10:21 pm   #8
Steve G4WCS
Battery removed and Id decided to recap around the 8.6v regulator while it was out. It was drifting slightly on warm up and when listening to a beacon, if a bit of impulse noise was received, it drifted a few hz for a second or so and settled. Service notes indicated checking the 8.6v rail. One of the removed caps looks to be dodgy
ID:	228954   Click image for larger version
Old 12th Mar 2021, 9:58 pm   #9
Steve G4WCS
Pvc piping has arrived. It looks and feels like it will work, and has a good bit of stretch to it
ID:	229028   Click image for larger version
Old 14th Mar 2021, 3:57 pm   #10
Steve G4WCS
Success
ID:	229131   Click image for larger version
ID:	229132   Click image for larger version
ID:	229133   Click image for larger version
Old 14th Mar 2021, 3:59 pm   #11
Steve G4WCS
Also spotted another couple of dodgy decouplers
ID:	229135   Click image for larger version
Old 20th Mar 2021, 9:06 pm   #12
g4wim_tim
Looks like a tidy old radio, well done !
Building and tinkering for over 50 years, from 807's to digital amateur TV.
g4wim_tim is online now
