24th Apr 2019, 9:16 am | #1 |
Codar AT5 Valve layout
Please could someone give me the valve layout as viewed from the front panel, left to right, front to rear?
Thank you. Roger |
24th Apr 2019, 9:40 am | #2 |
Re: Codar AT5 Valve layout
It's not in the service info, which is probably why you're asking the question.
It should be possible to work it out by comparing the wiring of the valve holders with the circuit diagram.
24th Apr 2019, 9:59 am | #3 |
Hi. Front row EF80 EF80 6BW6 rear row 12AX7 6BW6.
Hope this helps, Mick. |
24th Apr 2019, 8:27 pm | #4 |
Thank you Mick, very helpful.
Roger |
