26th Dec 2014, 8:40 pm | #1 |
Pye Pegasus
Does anyone have any connection information or even better service documentation for the military Pye Pegasus radio?
I have one here but it is not showing any signs of life at the moment. My connections are only a bit of guesswork at the moment so any information to help clarify things would be useful. Thanks in advance. |
26th Dec 2014, 9:30 pm | #2 |
Re: Pye Pegasus
I spent quite a bit of time in the 1980s supporting the base-stations that the Pegasus radios worked with as part of the "MOULD" network - see http://www.ringbell.co.uk/ukwmo/Page251.htm
The telephone handset is pretty much the same wiring as similar-era Clansman radios. The bits-inside-the-green-box are derivatives of the Pye "Olympic" M252 series; it was sold commercially [in a JCB-yellow case] to various bus-companies as the "Pye Beaver", and used identical crystals to the Olympic series. Later on it was replaced by the Australian-designed "FM900/914" series of synthesized radios. Alas I didn't manage to retain any of the manuals [they were marked "RESTRICTED" and we had to count them out and count them all back in again]. The only bit of pegasus I still have is this TBA810AS audio-output module... |
