Old 27th Dec 2022, 6:41 pm   #101
Aub
Aub's Avatar
Default Re: Quick question on the CODAR AT5, if anyone has one to hand.
Here's my first AM rig, Topband only. I built it in 1980, during my lunch breaks in the workshop at British Gas. The VFO is a 6C4 running at half frequency.
I used to power it from the power supply I'd kept from a dismantled Rigonda Symphony radiogram. The modulator uses a QQV03-10 in push pull. The modulation transformer is a HT transformer.
It used to get me all round Europe on CW ( when I was keen )
Hasn't been powered up for about 20 years. Don't all laugh at once!
Aub
ID:	270414   Click image for larger version
ID:	270415   Click image for larger version
ID:	270416   Click image for larger version
Life's a long song, but the tune ends too soon for us all.
Aub is offline
Old 27th Dec 2022, 7:01 pm   #102
Ian - G4JQT
Ian - G4JQT's Avatar
Very nice Aub. I wish I had facilities of bending metal better than just in a vice!
Here's my 60 metre copy of an AT5 for the AM channel on 5317 kHz:
ID:	270420   Click image for larger version
ID:	270421   Click image for larger version
Ian - G4JQT is offline
Old 27th Dec 2022, 8:13 pm   #103
Aub
Aub's Avatar
That's very good Ian. Looks like the AT5 power supply next to it. I must make something for 60.
73
Aub
Aub is offline
Old 27th Dec 2022, 8:46 pm   #104
Cruisin Marine
A Nice couple of rig's there guys
"Behind every crowd, there's a silver Moonshine"
Cruisin Marine is offline
Old 6th Jan 2023, 10:13 pm   #105
Aub
Aub's Avatar
There's another one of my old favourites in here:-
https://worldradiohistory.com/UK/Pra...PW-1966-11.pdf
Good old F.G. Rayer. He must have had a shed full of 160 and 80 AM rigs
This one has a beefier modulator.
Cheers all
Aub
Aub is offline
Old 7th Jan 2023, 4:37 am   #106
Bazz4CQJ
Bazz4CQJ's Avatar
Is that modulator a bit OTT? I've just mailed Ian re the bean can circuit. My recollection is that a pair of EL90's quite easily provided "full" modulation for the 03-10 and would probably do the same for a 5763 or 6BWB PA .
B
Bazz4CQJ is offline
Old 7th Jan 2023, 9:49 am   #107
Cheers all
Aub
I'm slowly obtaining the parts to build that. As usual it's the coils and variable caps that are difficult to source. Ed Dinning wound the transformers for me.
Station X is offline
Old 7th Jan 2023, 9:55 am   #108
Aub
Aub's Avatar
Yes, the EL90s should be more than enough for the QQV03-10 or the other valves. I suppose that modulator was a bit OTT but it's nice to have some grunt in reserve.
All the best
Aub
Aub is offline
Old 7th Jan 2023, 10:03 am   #109
Aub
Aub's Avatar
Cheers all
Aub
Hi Graham. Yes, old style coil formers are a problem aren't they. The fashion, over the last 40 years or so, to use toroids for everything hasn't helped. I'll see what variable caps I have in my collection. Is Ed winding you a proper mod. transformer, or is it a mains transformer as used in the article?
Aub
Aub is offline
Old 7th Jan 2023, 10:12 am   #110
Ed wound me a mains transformer for use as a modulation transformer.
I've sourced the 100 pF variable cap for the VFO. It's the 140pF 600V "Eddystone" variable cap I'm having problems finding.
I doubt I'll be able to build it on the small chassis Rayer specified. I try things first before bending up the chassis.
Probably best if I start a new thread on this rather than take this one off topic.
Old 7th Jan 2023, 10:47 am   #111
Bazz4CQJ
Bazz4CQJ's Avatar
All the best
Aub
That modulator has a lot of power output, but is the 12AX7 (ECC83) being asked to do a lot? The circuit I've used with the EL90's, uses an ECC83 in front of a another double triode, the first half being another amp stage and the second being the phase splitter for the output valves. I've certainly seen the single double triode in a number of circuits, but three stages is nice to have .
B
Bazz4CQJ is offline
Old 7th Jan 2023, 11:08 am   #112
AdrianH
AdrianH's Avatar
Default Re: Questions on 160/80 metre AM transmitters.
When I first thought about this project I just built a mod section using parts from an old TR1998/STR9X a VHF Aircraft TX/RXThat was driving a TT15 Valve for output, as in this circuit.
That uses two EC90's as output and driven by a EL90. HT 250 Volts and -11 Volts on the grids of the EC90's
Unfortunately the transformer labelled 2T2 was open circuit, the wires had corroded, but the output transformer 2T3 with thicker wire was still OK.
I thought I could still use the idea driving the two EC90's with an ECC83 in a phase splitter circuit and an EF91 pre-amp, basically like the typical Mullard audio amp circuit, but there must be something particular with the transformer driver as I could not get the required swing.
This was my circuit.
I note once again that the November 1966 PW posted by Aub, again uses a driver transformer, so I am guessing that it must take the grids positive and as such drive the outputs harder sinking more current through the output transformer and bigger swings etc. I would appreciate knowing if that is correct.
Also I am quite happy if others post ideas, projects within this thread as I am finding lots of interesting comments on low HF transmitters, perhaps there could be other stations to talk to if enough get built, dug out of cupboards etc.
Perhaps change the main Title to something suitable such as Questions on 160/80m transmitters ?
Adrian
Asking questions and learning, or trying to!
Youtube EF91Valve
AdrianH is online now
Old 7th Jan 2023, 11:16 am   #113
Thread title changed at OP's request.
Should we restrict this to valved transmitters?
Old 7th Jan 2023, 11:31 am   #114
AdrianH
AdrianH's Avatar
I am not too bothered, I guess we can keep this one valve, I know there were also Transistor circuits coming out in the 60's, so perhaps someone could start a transistor one if required.
Then there is still the Home made section for people's builds.
Adrian
Youtube EF91Valve
Old 7th Jan 2023, 4:22 pm   #115
Aub
Aub's Avatar
Thinking about modulators again. In the Topband transmitter that I posted the pictures of in this thread, I used a push-pull modulator as the single EL84 I'd been using when I first built it, didn't seem to produce enough audio. Over the years, I've wondered if the insufficient mod was more due to core saturation of the half wave mains transformer I was using as a mod transformer, rather than the power itself. I changed the circuit to push pull, using a 250-0-250 mains transformer with a QQV03-10 deployed for audio use. This worked very well. I suppose the issue of core saturation went away due to being push-pull.
Aub
Aub is offline
Old 7th Jan 2023, 4:37 pm   #116
I guess if the magnetisations from the currents for the single EL84 and the PA valve flowing through the modulation transformer were additive it could have caused core saturation.
Reversing the phase of one winding would have the magnetisations cancel each other out and so reduce the risk of saturation. That's the cunning thing about the Codar-type autotransformer approach, which allows the use of a seemingly-very-small transformer.
Old 7th Jan 2023, 4:52 pm   #117
Dave757
Aub
He certainly did! After his death a quantity of his sets were acquired
by my old friend Howard Turner(RIP) of Centre Electronics Birmingham,
and within a day or so of the purchase an irate relative called at the
shop and said they should not have been sold and demanded their return.
They were all returned except I believe for 1 set which had already been
sold on.
I wonder where they all are now?
Kind regards
Dave
Dave757 is offline
Old 7th Jan 2023, 6:46 pm   #118
G3VKM_Roger
G3VKM_Roger's Avatar
Hi All,
Since the thread has run onto Top Band/80m TXs other than the AT5, I have attached some pix of a very nice TX I used to own. It came from the estate of G3NHU but was built by G3HRK and used mobile with a Command set RX.
The mechanical construction was first-rate, the set ran a 6AQ5 PA, modulated by a pair of the same and used an ex-SCR522 mod transformer and several other ex-military components. I passed it on to a VMARS member a couple of years ago.
Belated HNY to all.
73
Roger/G3VKM
ID:	271050   Click image for larger version
ID:	271051   Click image for larger version
G3VKM_Roger is offline
Old 7th Jan 2023, 6:46 pm   #119
Aub
Aub's Avatar
Very interesting. Yes, where are they now? He also did designs for 4 metre and 2 metre AM rigs. I've got a 2 metre one somewhere, but I won't post it in this thread 😄
Aub
Aub is offline
Old 7th Jan 2023, 7:52 pm   #120
Aub
Aub's Avatar
Yes indeed. Quite clever.
Aub
Aub is offline
