29th May 2018, 10:05 pm | #1 |
Eddystone Receiver.
I’ve acquired this radio recently and am trying to track down the model, looking at google it seems to be possibly an 840 but there are differences. It's also been ‘got at’ works to a point but won’t receive anything other than random static and whistles. Has a non standard mains transformer fitted, some strange modifications to various things and the smoothing cap just loose inside, it reformed OK on my limiter though. Anyone got any ideas what it is so I can find the right schematics?
29th May 2018, 11:39 pm | #2 |
Re: Eddystone Receiver.
It does indeed give all the appearance of being an 840C, with its late model case, the linearised frequency scaling resulting from the 'C's variable ratio tuning drive and 480kHz to 30MHz coverage split into 5 bands. If so, the mains transformer would have been an addition to this originally AC/DC set- maybe fitting the transformer displaced the smoothing capacitor and they then lost interest in finishing things off properly, it's not unusual to encounter modified sets that started off as "nice idea" and ended in "but...."!
Hopefully, the 840C circuit will at least be a starter. |
30th May 2018, 8:57 am | #3 |
Have a look at the Eddystone User Group website, where you'll find a vast amount of information.
http://eddystoneusergroup.org.uk/ Andy |
30th May 2018, 7:34 pm | #4 |
I might recognise that one. Does it have a circular patch of rust on the case bottom?
Please may we see the transformer? |
31st May 2018, 5:35 pm | #5 |
Here’s some more pics of the radio. It does seem that it started life as an 840c but the knobs at the front are different, a sensitivity control has been added as well as other mods. Don’t know what the other things are on the back panel. Mr bodger has had a good go! The radio below is completely homebrew so the guy who had these must of knew a bit about it!
31st May 2018, 6:22 pm | #6 |
Thanks for the pics. No it is not the same one I knew. Blooming great transformer that is!
I put one of the RS kit transformers in mine where the primary was 230-240V prewound, you make your own secondaries. The object was to change from U series to E series valves with lesser requirement on heater cathode insulation. I had the idea that was why it had hum on the LO when working at high frequencies. It didn't seem to be HT related. Everybody on CW @ 14MHz and above had a T3 note - worse on 28MHz. Interesting on SSB... I also reckoned that isolation from the mains was no bad thing. I could see no need to run it on DC - ever. At the time, when I was an SWL, I hoped it would be a step up from the Trio 9R59-DS I already had. The truth of it - not much different except that the construction was much more rigid. I hope you enjoy putting it to rights. I would keep a transformer, just maybe not that one. It looks good for something else needing many more Watts. Last edited by Jon_G4MDC; 31st May 2018 at 6:32 pm. |
31st May 2018, 6:38 pm | #7 |
It is a dirty great transformer! I think it’s going to take me a while to try and decipher what mods have been done and why/where they are connected with this one. Be nice to make it work as it should
31st May 2018, 7:03 pm | #8 |
Good luck. I might have some info stored away somewhere...
I used to have the 840C instructions and circuit as a paper copy. It seems my Eddystone folder of "gen" has nothing on the 840C so in the short term it is of no help. |
31st May 2018, 7:30 pm | #9 |
Looks like a transformer from old Marconi test gear maybe? They certainly used good build quality and often unusually high ht windings. That is in my opinion.
Rob
31st May 2018, 9:41 pm | #10 |
That transformer looks to be a high quality vacuum-impregnated type, but of monster proportions for the job in hand.
It looks like rather a lot of the Eddystone circuitry has been replaced, but what with? I suspect there is no circuit for what it's become floating around anywhere. It may be easiest to either use this set as a parts donor for restoring another, or to just treat it as a cabinet with a nice tuning drive and use it as the basis of something of your own (making a better job of it than the last guy) David
31st May 2018, 10:00 pm | #11 |
I’ve included a couple of under chassis pics, it’s just a mess!
I think I’ll just add it to the to be fixed pile and try and get it working better than it does by replacing knackered components and hoping for the best! It must of worked at some point in its current configuration |
31st May 2018, 10:56 pm | #12 |
There's no accounting for what some folk do with things.... Is the tuning cord really scraping around what appears to be a meter casing fixed in place of the magic eye holder? Yes, that is a huge mains tranformer, and a rather nice one too- it certainly is reminiscent of ones found in Marconi stuff. The 840C doesn't really need anything bigger than the sort of thing that would be found in a mid 'fifties AM/FM set to run its valve complement.
31st May 2018, 11:09 pm | #13 |
If you were to restore it to the original 840C configuration, you'd need to be very careful to get all the mountings and isolating components right
1st Jun 2018, 11:44 am | #14 |
Although I've never owned nor worked on the 840C, I have owned and worked on many Eddystone receivers of the 'communications' type. Looking at the under-chassis wiring, I find it difficult to believe that that construction is original. If the set were mine, I'd retain it as an A.C. mains only model (perhaps replacing that mains xfmr.) and a complete re-do of the under chassis wiring - aiming at something comparable to the excellent standards one usually associates with such Eddystone kit.
So yes, a lot of work involved in all that - but the resulting sense of satisfaction would make it all worthwhile! Al. |
1st Jun 2018, 11:51 am | #15 | |
Al. |
1st Jun 2018, 7:26 pm | #16 |
If you need a picture of layout then I have 2 sets here.Just PM me.
