Old 19th Jan 2021, 8:30 pm   #21
osx86apple
Default Re: Decca Decola Restoration
Thank you everyone for your replies and assistance. It’s a lovely item and certainly hasn’t had any signs of repair, just thick layers of dust which is exposing a lovely clean/shiny chassis!
ID:	224960   Click image for larger version
osx86apple is offline
Old 20th Jan 2021, 10:34 am   #22
rontech
Originally Posted by vidjoman View Post
The one I saw at a Hi-Fi show had a Garrard 301 with a Decca arm and cartridge. It was about 1962 and was priced about £1000. Sounded far better than anything else at the show.
I have no recollection of the turntable but the arm was the Decca FFSS magnetic. That arm / cartridge was considered by far the best available at the time.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 20th Jan 2021, 11:35 am   #23
vidjoman
I’m sure it was a Garrard as it was white. The Collaro 200 was a deep cream colour.
vidjoman is offline
Old 20th Jan 2021, 12:04 pm   #24
Heatercathodeshort
Heatercathodeshort's Avatar
By the look of the components it appears to be a later version, certainly early 60's.
Those large Dubiliar .47uf coupling caps to pin 5 of the EL34s look original and probably have small leaks by now, enough to damage the EL34 valves and the output transformers.
Replace them before switch on! Plenty of Mullard 'Mustard. caps that will be OK unless you are very unlucky! John.
Heatercathodeshort is offline
Old 20th Jan 2021, 4:12 pm   #25
Robint 47
Info from original Decca material i still have and now some 60 years old.Yes it used the Decca FFSS arm and the FFSS head Mk 2 white for stereo and green for 78 switching was on the pre amp control unit and from an official price list 1964 it cost 348 gns The Stereo Decola was also supplied as a seperates system here the deck was replaced by a garrard 301 in white with a Decca mk 1 head.
Robin
Robint 47 is offline
Old 20th Jan 2021, 5:03 pm   #26
ajgriff
ajgriff's Avatar
Originally Posted by Robint 47 View Post
..... from an official price list 1964 it cost 348 gns.
Well over £7,000 in today's terms. Easy to see why there aren't too many of them around.
Alan
ajgriff is offline
Old 21st Jan 2021, 1:34 pm   #27
osx86apple
Thank you all for your help. Does anyone have recommendations for suppliers who do the multiple capacitors in the cans ? I’ve never been a fan of restuffing !
Old 22nd Jan 2021, 6:24 pm   #28
Heatercathodeshort
Just a thought. If you want to hear the full capabilities of this Decca stereo Decola look out for a good condition recording of Ted Heath and his music, Decca phase 4 stereo PFS 4018. It was recorded in 1962 and is quite an extraordinary recording.
If you can turn the volume up, all the better! Brings back a lot of memories for me. Regards, John.
Old 22nd Jan 2021, 8:16 pm   #29
osx86apple
Definitely going to try and get hold of this, managed to find one for sale, will keep my fingers crossed I get it
Old 22nd Jan 2021, 8:39 pm   #30
HamishBoxer
HamishBoxer's Avatar
John beat me to it, those large .47uF caps will not doubt be failing or fail under working conditions. Had more boost caps fail when servicing valve TV's than hot dinners with those type/colour of caps. Not to mention when they were across the mains switch.
HamishBoxer is offline
Old 24th Jan 2021, 10:26 am   #31
osx86apple
Yes they will be swiftly replaced along with some electrolytics in the power supply, I’m not taking any chances!
Any recommendations for the output stage what to replace the .47’s with ? Being somewhat a rarer item id rather go for some better quality components
Old 24th Jan 2021, 11:52 am   #32
HamishBoxer
Did someone mention some oil filled tubular caps recently? Not sure if they were from JustRadio or not.
Not that I think any modern well rated caps wont be fine.
Old 24th Jan 2021, 5:42 pm   #33
John Caswell
osx86 wrote
"Any recommendations for the output stage what to replace the .47’s with ? Being somewhat a rarer item id rather go for some better quality components"
It depends upon the HT voltage but if under 400V I would go for either Mullard C296 capacitors (colloquially called "mustard caps" here ugh!!!) or or any one of the modern PET type capacitors such as the MKT 1813 types.
John
John Caswell is offline
Old 24th Jan 2021, 6:21 pm   #34
Herald1360
Herald1360's Avatar
I'd go for an axial polyprop 1000V type. They're of a size comparable with the existing caps. You might be able to conceal them in the old cap cases- they look like the two-tone blue grey mixed dielectric type in a rigid plastic outer shell.
Not particularly cheap- you could be looking at £15 or so for a pair, but pretty much bomb proof!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 25th Jan 2021, 9:59 pm   #35
osx86apple
Making some progress today
Concentrated on the PSU chassis first, started to clean it, underneath the thick layers of dust it’s very well preserved and clean. Removed the large 100uf and the triple 32/32/16 uf cans. Suitable replacements are on the way keeping to original style.
Old 3rd Feb 2021, 9:55 pm   #36
osx86apple
So, it’s had lots of work, turned out to be more work than I’d initially thought, but well worth it! , link below showing it’s first test. Few more bits to do, but it’s sounding good!
https://youtu.be/5kvPCxo97Yc
Old 4th Feb 2021, 9:48 am   #37
Richardgr
Just had a listen - lovely mellow sound! Form and function, like an old Rolls Royce or Daimler. Quality like that will never be produced again.
Richardgr is offline
Old 4th Feb 2021, 12:21 pm   #38
MurphyNut
MurphyNut's Avatar
It's not always easy to hear what a bit of vintage equipment will actually sound like on youtube, but in this case it sounds fantastic!
I assume you're playing an LP record?
Clive
MurphyNut is offline
Old 4th Feb 2021, 1:09 pm   #39
Herald1360
Herald1360's Avatar
Interesting comments...... I'm not sure I'd agree that equipment of the quality of the Decola is no longer produced though equipment in the style would have to be bespoke.
As for listening via Youtube, that's totally dependent on the poster's recording equipment and the listener's playing equipment, never mind what happens in between as well. In my case the sound I heard on my tablet's speakers was decidedly "thin" and in no way "mellow", just clear and apparently undistorted.
....__________
Old 4th Feb 2021, 3:11 pm   #40
osx86apple
Unfortunately my iPhone nor YouTube will do the sound quality any justice, however it sounds so rich and detailed in the flesh. I was using Aux input this time whilst I’m wait for some rubber rejuvenator for the idler wheel on the turntable
