Old 3rd Oct 2023, 12:18 pm   #1
PaulR
PaulR's Avatar
Default Quad FM3 bulb holders
Just a very small success but it may be helpful to others.
I was given an FM3 by a friend. It needed minor work (new smoothing cap and cleaning the tuning cap contacts) after which it worked fine.
The tuning indicator lamps had blown and like many others found the silly spring bulb holders fell to pieces when I wrestled the old lamps out.
I found that I could extract the rivets which held them together. I then used half inch brass 10BA screws and nuts to reassemble them. Like everything else the new lamps were not as well finished as the existing ones. In particular the solder blob bottom contact was very small and only made intermittent contact with the screw head. I augmented this with a blob of new solder and this helped a lot.
A small success but others may find it useful to know that you don't have to replace the lamps with LED ones if the holders disintegrate.
Paul
PaulR is offline
Old 6th Oct 2023, 10:19 am   #2
60136 Alcazar
60136 Alcazar's Avatar
Default Re: Quad FM3 bulb holders
I have also used the 'enhanced solder blob' technique on current production incandescent mains lamp bulbs, which frequently have a visible connection wire poking through a smear of solder instead of a proper contact!
John
Progress consists of doing what you've always done - just more expensively.
60136 Alcazar is online now
Old 6th Oct 2023, 10:48 am   #3
PaulR
PaulR's Avatar
The base on the original lamp looked so much better finished than the new ones. I wonder whether they will last another 50 years
Paul
PaulR is offline
Old 6th Oct 2023, 1:30 pm   #4
vidjoman
Those spring lamp holders are ‘designed’ to stop the lamps from working loose. A real pain to remove the lamp but I found that if you try turning the spring in a clockwise direction, same as screwing a lamp in, whilst unscrewing the lamp anti-clockwise it should be easier. The motion of screwing in causes the spring to expand and make it easier to insert the lamp. Unscrewing causes the spring to tighten.
vidjoman is offline
Old 6th Oct 2023, 4:24 pm   #5
PaulR
PaulR's Avatar
I did actually try that sort of thing but it didn't help. I think that the bulb screw was tarnished/slightly corroded to that it wouldn't turn easily. I managed the dial illumination one with no problem but the tuning indicator ones were a different matter.
Another case of using something way past its design life I suppose.
Paul
PaulR is offline
Old 6th Oct 2023, 7:21 pm   #6
radiomobile
Many '60s car radios used the spring type bulbholders for LES bulbs, possibly the same type as the Quad FM3. After much cursing, and occasionally damaged fingers, we found the solution to remove the dud bulb. First remove the glass bulb by breaking it, taking care to avoid splinters etc. by using a piece of cloth and crushing it. Then apply some oil (it is after all a thread) then grasp the edge of the base with miniature pliers and proceed as in the previous post by "vidjoman".
radiomobile is online now
