13th Sep 2009, 11:12 am | #1 |
Bush VHF64 - ECC85 gobbler?
Hmm, I'm without FM again. AM is OK but I never listen to anything on that. Looks like I'll be on my third ECC85 in 6 months. Anyone else experienced this "luck"?
Brian. |
13th Sep 2009, 11:21 am | #2 |
Re: Bush VHF64 - ECC85 gobbler?
Not really, but there are plenty of East European and Russian ECC85s around which are not long lived. You could check R1 and its associated decoupler C2 (Bush service sheet numbers) if it's the RF section which is failing.
Finally, change the screening can to a blackened one. This results in a very noticable reduction in valve temperature and helps to reduce frequency drift (although the Bush VHF boxes are not bad in this respect). Leon. |
13th Sep 2009, 11:24 am | #3 |
ECC85s are well known for their short lives, but your experience has been particularly bad.
It would be worth checking that the heater voltage is what it should be. Paul |
13th Sep 2009, 12:11 pm | #4 |
13th Sep 2009, 2:37 pm | #5 |
I've not had a lot of trouble with ECC85's. I'm wondering if the apparent short life is a 'recent' problem. I have several radio's with ECC85's. One is a Stella 160 with all originals...something like 45 years old. Then there is a Fergy 383A with an original and finaly a Baird 301 with an ECC85 that's been in there over 20 years. Admittedly these don't get used every day and probably less than once a month but I seem to remember that our old Fergy 383A that we used to have in the 60's never failed on FM and was still working when we got rid of it.
Leon could be right about Eastern European versions that are not made to the same standard as the originals. Rich.
13th Sep 2009, 2:46 pm | #6 | |
I don't know of a special quality ECC85 variant (there's no E85CC) and wonder if the construction pushed the boundaries somehow. The heater consumption is higher than you'd expect for a twin triode. Paul |
13th Sep 2009, 3:44 pm | #7 |
The one that appears to have failed is branded "Ferranti" so gawd knows where that came from. Got a Mullard on the way and crossed fingers.
Am I correct in thinking that the FM module must be removed from the set in order to access the innards for testing? Brian. |
15th Sep 2009, 7:40 pm | #8 |
With the tested yellow-print Mullard in I have music again. Got a NOS Mullard on the way which I will store behind the set ready for a quick changeover if one should prove necessary in the future. I have left the screening can off for cooler operation.
Thanks for the suggestions & comments chaps. What lovely sounding sets these are. Brian. |
15th Sep 2009, 10:53 pm | #9 |
16th Sep 2009, 12:56 am | #10 |
16th Sep 2009, 10:40 am | #11 |
FWIW here are the two that failed.
I was so glad to have received the Mullard and couldn't get it in the set quick enough so I didn't compare. Last edited by Station X; 16th Sep 2009 at 10:50 am. Reason: Image converted to thumbnail. |
16th Sep 2009, 11:19 am | #12 |
The Ferranti one looks like it has a Mullard Blackburn factory etch code (B3A) - 1953 manufacture?
The chunky micas with big star edges of the Bentley Acoustic suggest it could be made by RFT in East Germany. The bright red pin seals also suggest Eastern Europe (or Russia but then it would have a sharp end on shiny pins and a dish type getter). |
16th Sep 2009, 11:48 am | #13 |
Brian
It would be a good idea to follow Paul and Nick's advice and check that the heater voltage is OK and that the mains voltage selector is correctly set. If a fault of this type exists there is a good chance that you will kill your new ECC85. John |
16th Sep 2009, 12:07 pm | #14 | |
Geof (a fellow Ongarterian ) |
16th Sep 2009, 12:51 pm | #15 |
John, the voltage selector was set at 250V. This was giving HT (measured at the ouput transformer top of primary) of 280VDC and LT (measured at pilot light) of just 4.5VAC! I've reset to 230V and this now gives me 296V HT(spec 300V) and 5.3V LT. Even though the LT was low the pilot lights were bright and the heater glows looked normal. I measure from the pilot light "pip" connection to a point on the chassis since this is the most convenient access. The diagram shows the lights in parallel across the '6.3V' secondary.
Geof, are you still living in Ongar? Brian. |
16th Sep 2009, 1:02 pm | #16 |
The heater volts seem way out! Are you sure your meter's accurate? What does it read on other sets with E-series valves?
Nick. |
16th Sep 2009, 1:03 pm | #17 | |
[QUOTE=geofy;271861]
I always wondered whether the 6.3V had anything to do with the typical 6V accumulator discharge voltage (12.6V pro rata for a 12V battery)? This is pretty constant at around 6.3V (12.6V) for a reasonably light load relative to battery capacity. Chris |
16th Sep 2009, 1:21 pm | #18 |
I've swapped meters and still get the same reading. I've also gone underneath the chassis and measured the same low HT at the ECH81 base.
So either there is a shorted turn or two in the transformer 6.3V secondary or something is drawing more current than it should from that secondary. Oh dear Brian. |
16th Sep 2009, 1:44 pm | #19 | |
Rich.
16th Sep 2009, 1:51 pm | #20 |
That's what I thought, which leaves something hogging more current than it should. Maybe the two pilot lights? All the valves apart from the Russian 6P14 replacement for the original EL84 are Mullards.
Update: I've just loosened one of the bulbs so that it is out of circuit. LT is still 5.3V. Last edited by monoman; 16th Sep 2009 at 2:03 pm. |
