31st Dec 2015, 1:36 pm | #1 |
Cathode bypass capacitor.
I need to replace a 25uf 12v electrolytic capacitor. It is the cathode bypass for an EL84. Will a 30uf 50V bipolar do the same job or will the sound be degraded? Is there a better equivelant out there many thanks |
31st Dec 2015, 2:05 pm | #2 |
Re: cathode bypass capacitor
Hi BigClick,
Considering whe broad tolerance range of electrolytic capacitors I would say it won't matter that much. Just try and listen, but I think it will work. BR Stef.
Failing to prepare is preparing to fail ... |
31st Dec 2015, 2:06 pm | #3 |
If you want a closer match use 22uF.
31st Dec 2015, 2:12 pm | #4 |
If the 30uF bipolar is what you have in stock use it, it will be fine. If not in stock it would be cheaper to buy a 22uF 12 volt part (or even 33uF).
31st Dec 2015, 2:23 pm | #5 |
thanks again folks good info and fast replies
I dont have any components as yet, I am doing a list at the moment and I I cant find a 22uF 12 volt on the Cricklewood site, but it doesnt mean they dont have it lol. The bipolar 30uF 50V is the nearest I have seen on the site. |
31st Dec 2015, 2:27 pm | #6 |
This'll do the job:-
http://www.cricklewoodelectronics.com/22M35.html If you don't want to use a radial component this'll cost a bit more:- http://www.cricklewoodelectronics.com/22A100.html Don't waste money on a bipolar component.
31st Dec 2015, 3:02 pm | #7 |
A 33uF 16V or even 25V electrolytic should be almost trivially cheap from most suppliers, and will be very compact. Do you have a Maplin's nearby?- I know they might be a bit infra-dig in the eyes of hard-core electronics constructors but they ought to be able to come up with something. If you can find a 105 degree rated component, rather than 85 degrees, go for that- even if the location doesn't get to 85 degrees, many valve chassis eventually get pretty warm and the higher temperature component will have a substantially better chance of a long life. Avoid strange-name bargain components from auction sites....
Edit: Just followed Graham's links- they'll be fine. Last edited by turretslug; 31st Dec 2015 at 3:12 pm. |
