27th Dec 2015, 7:26 pm | #1 |
Marconi valve
Hello forum.
You can probably tell I'm new to radios by my question. I have recently acquired a Marconi Z14 1N5G DF33 valve and have tried to find a catalogue of some (any) sort online. The only reference I have found are a couple for sale. Can any one please direct me to some information? I dont even know what years they were made-and which radios used them. Thank you in anticipation! Jonathon. |
27th Dec 2015, 7:35 pm | #2 |
Re: Marconi valve
I'm not sure what information you're seeking, but this is a good starting point:-
http://www.r-type.org/exhib/aac0058.htm
27th Dec 2015, 8:02 pm | #3 |
Re: Marconi valve
These were used in battery portables.The make of which I cannot at present remember Marconi or Ever Ready?
1940's.
27th Dec 2015, 8:27 pm | #4 |
Re: Marconi valve
Thats a very good start thank you---they changed the number!
28th Dec 2015, 12:03 am | #5 |
Re: Marconi valve
A DF33 is an RF pentode with an octal base and 1.4 volt filament, I suspect the others are equivalents.
Peter |
28th Dec 2015, 10:36 am | #6 |
Re: Marconi valve
Yes - Z14 is a GEC-Osram type of number, 1N5G an American number, and DF33 a British/European number. All for the same equivalent valve, a pentode on an Octal base, with 1.4V filament.
28th Dec 2015, 11:54 am | #7 |
Re: Marconi valve
I seem to have a new old stock Z14 so I m trying to find a radio to fit it!
Even if I don't succeed it's a very nice ornament and didn't cost much. Certainly looks unused. I wonder if there is a way of rectifying down to 90 volts without using expensive batteries. |
28th Dec 2015, 12:07 pm | #8 |
Re: Marconi valve
It's usual to do things the other way round, but someone will doubtless know of one.
There are many designs for mains power supplies around, including this one: http://www.vintage-radio.com/project...y-set-psu.html |
28th Dec 2015, 12:51 pm | #9 |
Re: Marconi valve
It was used in sets such as the Cossor AD41 http://www.radiomuseum.org/r/cossor_...able_ad41.html
Bush BP90 http://www.radiomuseum.org/r/bush_bp90_bp_90.html Ever Ready Model C http://www.radiomuseum.org/r/ever_c.html This was a commonly used series of valve until the use B7G battery valves which rapidly took over after 1946 (earlier in the US) You should have no trouble finding a set that used that valve. Just look on RMorg for Battery sets between 1939 and 1947. As for HT you can get 10 PP3's from Poundand for £5. Unless you are going to use it a lot that's really quite economic. However if you want to make an eliminator there are many designs around and the one linked by AC/HL has been built by many. Good luck with your search Cheers Mike T
28th Dec 2015, 2:02 pm | #10 |
Re: Marconi valve
Or you could build a one-valver around it ...
28th Dec 2015, 4:41 pm | #11 |
Re: Marconi valve
What a good idea, will look the part too. (Lots of websites with one valvers (try one tube too))
28th Dec 2015, 6:32 pm | #12 |
Re: Marconi valve
I know. I've a cat!
I'm looking for a radio to fit the valve and it shouldnt be too difficult.. I've always wanted to build a radio and that is now an ambition. What a useful forum. Jonathon |
