14th Jan 2015, 10:30 pm | #41 | |
Re: First radio (DAC90A)
I wasn't suggesting you should change the mica's. just that doing so would alter the RF alignment possibly enough to lose sensitivity. |
14th Jan 2015, 10:42 pm | #42 | |
To answer the basic question...no alignment is not difficult but it requires a) an RF signal generator, b) the correct alignment tools (you can make good one's from PLASTIC knitting needles), c) the alignment instructions and d) knowledge of how to use the RF generator.
14th Jan 2015, 10:43 pm | #43 |
14th Jan 2015, 10:49 pm | #44 | |
I'll leave alignment practice for another set and another day, keep an eye out for an RF sig gen too. |
16th Jan 2015, 1:00 pm | #45 |
I have the new UBC41 to try tonight, hopefully it will clean things up a little
When is a set declared fit for use? This one is working, the af stage voltages are now reading good but it does have some of rf/if stage voltages and currents, mostly low, would that matter? T-cut brought the cabinet up to a lovely shine |
16th Jan 2015, 1:02 pm | #46 |
Yes certainly the UL41 base.Sorry have I got confused here thinking you had a hum on sound?
16th Jan 2015, 1:37 pm | #47 | |
You can hear some mild hum between speech etc but I have no idea what a "good" DAC90A sounds like really, too used to the modern stuff where it is silent between speech. |
16th Jan 2015, 2:06 pm | #48 |
You should have better sensitivity than that. Double check the frame aerial connections and the wavechange switching arrangements. I assume you've already cleaned the wavechange switch contacts, but do them again
16th Jan 2015, 2:15 pm | #49 |
Thanks, I'll re-check the aerial connections and aerial continuity tonight, I'll also clean and check the switch again.
The high end of my MW scale is pretty bogged up with noise from a SMPS, not sure if its the printer or HDD psu, certainly chucking out some noise, I might try shutting that lot down for a test. |
16th Jan 2015, 2:18 pm | #50 |
Yes, shut down all potental sources of interference before drawing any conclusions.
16th Jan 2015, 3:11 pm | #51 |
Hi Dave, My DAC90A certainly receives more than three stations so the sensitivity seems low. The internal loop is quite directional so rotating the set might make a difference.
You mention low voltage measurements, if they are only low by 10% I wouldn't expect this to have much effect so the problem must be elsewhere. Paul's suggestion is a good starting point. |
16th Jan 2015, 3:38 pm | #52 |
These were the values i got with a Fluke DMM, (tech sheet values in brackets)
UCH42 Pin 2 89v (98) Pin 3 54v (47) Pin 5 60v (47) Pin 7 0.67v (0.8) UF41 Pin 2 90v (74) Pin 5 60v (47) UBC41 Pin 2 59v (74) Pin 7 0.33v (1.3) R8, V2&3 cathode resistor shows a drop of 0.263v across 330r which gives 0.0008mA? R2, V1 cathode resistor shows a drop of 0.62v across 220r which gives 0.0028mA? The UBC41 values were with the old valve, I will try the new one tonight. |
16th Jan 2015, 3:51 pm | #53 | |
16th Jan 2015, 4:26 pm | #54 |
D'oh!
16th Jan 2015, 7:35 pm | #55 |
Well, the UBC41 made a massive difference, many more stations now on MW, easier to tune too. It has also reduced the interference I was getting from the SMPS in my PC stuff a lot. Can anyone explain why that valve is so vital?
The LW is still dead, some noise and a whistle at one end and a gurgling sound at the other end very dead in the middle, no hum though The noise I have on MW is more like a sloshing sound than a hum now, a shhhhhhh sort of noise. Don't know if that's normal or not. |
16th Jan 2015, 7:51 pm | #56 | |
16th Jan 2015, 8:10 pm | #57 |
Yes I figured that
It just seemed odd that this one was singled out many posts ago as being worthy of changing. I think this is the one with the detector and AGC diodes in it, would a failing detector do it? |
17th Jan 2015, 12:03 am | #58 |
A failing detector diode would indeed mean that only the stronger signals would be received,, probably 5 Live, Talksport & Absolute R. in your area. What puzzles me is why some of the voltage readings you get with your Fluke DMM are lower than the values in the Service Sheet, given that a DMM has a very high impedance, usually 10Megohms, and thus imposes very little load on a circuit, whereas the readings on the Service Sheet would no doubt have been taken with an AVO 7, which is only 1000 OPV, or, at best, an AVO 8 (20000 OPV).
17th Jan 2015, 2:16 am | #59 |
The HT is down though, which will suppress all the voltages derived from it, all things being equal.
I'm surprised that a new UBC41 has made such a difference. It is basically an AF amplifier triode, though it's true that it also contains the detector and AGC diodes. I suggested it might be responsible for the hum, but the other effects are unexpected. |
17th Jan 2015, 9:32 am | #60 |
Those three stations were indeed the only ones I could get before!
I have won a very nice Avo8 and should have it monday/Tuesday I will do another complete voltage check with that just for comparison. I don't mind the HT being down but only if it's not being dragged down by a failing component. I would like to use this set in the office so want it to be fairly stable and reliable as possible. What sort of current should be seen through the main HT dropper, I think it's R13, 10k? Apart from valve bases and the mica caps, there is little left to change really. I'll check the rating on the dial lamps too, I hear they can be wrong as well. |
