Old 15th Nov 2010, 3:41 pm   #101
Tractorfan
Tractorfan's Avatar
Default Re: Unusual BS1363 Socket Designs
It would probably fit 2amp, 5amp & 15amp 2 pin and unshuttered 3 pin sockets, albeit loosely . Having said that, it has a "continental" look about it.
Cheers, Pete
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 3rd Jan 2012, 9:04 pm   #102
ben
ben's Avatar
just seen this online fitted to a tandberg reel recorder. Looks rather lethal, is it a 'fitall'?
Name:	weird mains plug.jpeg
Regards,
Ben.
ben is offline
Old 3rd Jan 2012, 9:09 pm   #103
Lucien Nunes
Yes. The pins rotate through 90° to lock, if you're lucky. Fitnone might have been a better name. Something not quite right about the wiring too!
Lucien
Lucien Nunes is offline
Old 3rd Jan 2012, 10:54 pm   #104
Brased
Yes I remember them. Probably slightly safer than using bared wires stuffed into the socket with matchsticks.
Brased is offline
Old 4th Jan 2012, 9:47 am   #105
Ed_Dinning
The up lock for the pins did not always work either (it was controlled by small lever and shutter arrangement). This often led to fireworks on metalclad, floor mounted stage sockets.
I still have an example with slightly melted round pins.
Ed
Ed_Dinning is online now
Old 26th Jul 2013, 4:13 pm   #106
Socketman
Originally Posted by Colourstar View Post
Originally Posted by Tractorfan View Post
Just for information, all 13amp plugs & sockets past and present were/are BS1363
Cheers de Pete
Just to throw a spanner in the works, I've noticed that out of the two externally identical MK switched single sockets in my photo, the cream one is to BS1363, whereas the brown one is to BS2814...
Steve
Please forgive me for this late addition, but I can add something here. The original 1947 BS 1363 standard was for unswitched sockets only, that was a deliberate decision made by the committee. However, there was a demand for switched sockets and a separate standard was published in 1957, BS 2814:1957 "Two-pole and earthing-pin flush-mounted 13-Amp switch socket-outlets for A.C. circuits up to 250 Volts". It took another 10 years before everything was brought together in the revised BS 1363:1967 "Specification for 13A plugs, switched and unswitched socket-outlets and boxes".
The paint spec mentioned by Herald1360 is not "BS 2814" but "BS EN ISO 2814" - something completely different.
Socketman is offline
