Old 18th Sep 2019, 11:32 am   #1
Welsh Anorak
Welsh Anorak's Avatar
Default Dual Turntable motor fault.
Hi
I thought I'd eventually have a look at my old Dual 505 turntable which stopped working years ago. After replacing the microswitch (O/C) and the RIFA capacitors, the motor trembles but doesn't turn. Both coils measure around 1.8k and it spins freely. Motors aren't my strong point - is there anything I can do?
Name:	IMG_0022 (Small).JPG
ID:	190419   Click image for larger version
Name:	IMG_0024 (Small).JPG
ID:	190420   Click image for larger version
Name:	IMG_0025 (Small).JPG
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 18th Sep 2019, 9:19 pm   #2
wowitsanamstrad
Default Re: Dual Turntable motor fault.
replacing the capacitors usually sorts the motor,
wowitsanamstrad is offline
Old 18th Sep 2019, 9:52 pm   #3
Herald1360
Herald1360's Avatar
Does it spin up if you "kickstart" it?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 18th Sep 2019, 11:51 pm   #4
Michael Maurice
Michael Maurice's Avatar
He's replaced the capacitors. See post #1
Forum Moderator
Michael Maurice is offline
Old 19th Sep 2019, 11:08 am   #5
Herald1360
Herald1360's Avatar
You might have a shorted turn on one of the motor windings which wouldn't show up on a resistance check. Try inductance checks or a "ring" test if you can do them.
....__________
Old 19th Sep 2019, 12:18 pm   #6
Welsh Anorak
The reason I got it out of its slumber is that another identical turntable has come in for a simple repair. So I think a bit of swapping is in order!
Yo answer your question, it stubbornly sits there trembling.
Glyn
Old 19th Sep 2019, 12:42 pm   #7
Diabolical Artificer
Diabolical Artificer's Avatar
Have you re- checked your connections Glyn? Also did you use the right value caps and they're not actually snubbers, lastly make sure the caps you subbed are ok and not shorted or leaky. Short of that try a different value of cap.
Andy.
Old 19th Sep 2019, 1:12 pm   #8
Welsh Anorak
Hmm.
When I put my motor in the good turntable it spins merrily BUT soon there's an unpleasant smell and the feed resistor (5k1, 5W W/W) is unhappy. This runs relatively cool in the customer's machine. Oddly, my board won't spin his motor at all! Confused at this point, but as it seems my motor is duff anyway there's not much point in going further.
Glyn
Old 19th Sep 2019, 1:16 pm   #9
Beobloke
It sounds like you have motor troubles but, as an aside, I always replace all the components on any of these that I service. The resistor runs hot and eventally the coating burns off and it stinks the whole time, plus one of the capacitors has a tendency to explode when it gets old!
A complete kit of compoenents is available on a "well known auction website" for only 9 which makes it a no-brainer in my book.
Beobloke is offline
Old 19th Sep 2019, 5:18 pm   #10
Norman Raeburn
Hi Glyn, I have a scrap 505 which I believe the motor is ok. You are welcome to try it foc. Just let me know. Norman
Norman Raeburn is offline
Old 20th Sep 2019, 1:31 pm   #11
Welsh Anorak
That's very kind of you, Norman, I'd appreciate that as I'd already invested in the capacitors, a stylus and belt before I realised it was the motor.
I'll send you my details via PM.
Glyn
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
