Old 12th Sep 2019, 4:34 pm   #1
MikeCross
Default Leak Delta AM-FM Tuner
I wish to listen to the MW ( 5 Live for sport ) and have found my old Tuner which has not been used for at least 10 years.
The FM side works well but the AM side is totally dead. Its gives me the feeling that perhaps the power is not being switched to the AM tuner circuit.
Does any one have a schematic for this Tuner and has anyone experienced
this fault.
Mike
MikeCross is offline
Old 12th Sep 2019, 4:46 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Leak Delta AM-FM Tuner
ElektroTanya appears to have a service manual: https://elektrotanya.com/leak_delta_.../download.html
paulsherwin is offline
Old 15th Sep 2019, 8:41 am   #3
MikeCross
Thanks Paul.
Making a start this week.
Old 15th Sep 2019, 10:42 am   #4
Sideband
Sideband's Avatar
Try cleaning the wavechange switch first.
Sideband is offline
Old 15th Sep 2019, 12:09 pm   #5
theredhouseinn
theredhouseinn's Avatar
Most of the blue electrolytics will have gone leaky to some degree. Especially the two AF o/p coupling caps, these go leaky and can feed up to 700mv dc to the i/p of your amp. Not good for a dc coupled amp.
theredhouseinn is offline
Old 18th Sep 2019, 8:03 am   #6
MikeCross
Nothing more than resistor gone high and a reset of the power supply.
One bulb to replace and a change of the two output caps when they arrive.
Now onto it's Delta 70 brother.
Thanks for your help.
Old 18th Sep 2019, 9:04 am   #7
dazzlevision
Can you tell us which resistor, please?
dazzlevision is offline
Old 22nd Sep 2019, 9:28 am   #8
MikeCross
R1 on the AM board which should be 330k was well above 2M.
