Old 11th Sep 2019, 2:27 am   #1
avocollector
Default Selectest 50 meter - in pink??
Won this meter a week or so ago but when it arrived it was pink - appears to be the factory colour. Does anyone know if this is correct.
avocollector is offline
Old 11th Sep 2019, 6:06 am   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Selectest 50 meter - in pink??
Thought they were all beige-ish.
Can you see any unfaded plastic inside?
Radio Wrangler is online now
Old 11th Sep 2019, 7:26 am   #3
Superscope
Seen a few Pink ones whilst Trawling round the Internet looking for a Manual,
although whether this was an original colour is had to say.
The only one I have is beige, which seems to be the normal Colour.
Plastics do have a nasty habit of fading or worse still having Black/Brown blotches appearing over time.
As Radio Wrangler suggested, it might be worthwhile having a look inside to see the
Plastic that hasn't been exposed to Sunlight and Pollution over the years.
Would be interesting to know what you find.
Ian
Superscope is offline
Old 11th Sep 2019, 8:51 am   #4
barrymagrec
I seem to remember the one I used back in 1070 / 72 was pinkish.
barrymagrec is offline
Old 11th Sep 2019, 10:38 am   #5
AC/HL
AC/HL's Avatar
Mine's definitely grey. It was in a carry case when I bought it, which may explain why?
AC/HL is offline
Old 11th Sep 2019, 10:47 am   #6
turretslug
turretslug's Avatar
There's a MkII here that's on the pink side of beige- I suspect that they started off towards beige but head pink with sunlight etc. The MkIII was a "sensible but dull" lab grey. It's a shame that there isn't a bit more colour amongst test gear, a little while back Maplin were doing a budget analogue test meter in bright green.
Spotter moment- it's interesting to see a MkII with the printed-on-knobs range selection associated with later Selectest 50s- many have the legending fixed to the case under transparent acrylic (?) knobs. Well, they start transparent but go cloudy with age. There seem to be quite a lot of incremental detail changes of case, selector, connection post colouring and detail styling. The last Selectest 50s deleted the 2.5kV AC and DC multiplier terminal option (changing safety requirements ?) and adopted 1/3/10 ranging in a similar manner to AVO 8s.
turretslug is offline
Old 11th Sep 2019, 10:02 pm   #7
MotorBikeLes
I bought a Selectest (Mk 111 I think) just about 40 years ago, and that was pink. A few years later I came across a grey coloured one which appeared to be new or nearly so, but with its glass "fallen in". I fixed the glass, everything else was as new, so at a later date I sold off the pink one. Not long ago, I was given an old AVO (8 I think), never had a big AVO before, but still not used it. If i need an analogue meter, it is always the Selectest I use. Great meters.
Les.
MotorBikeLes is offline
Old 11th Sep 2019, 10:28 pm   #8
Lloyd 1985
Lloyd 1985's Avatar
I’ve Got one of those too, and yes, it’s pink! It’s a very faded pink, but definitely pink! The + and - terminals have been replaced on mine. I actually used mine the other day for monitoring current on a capacitor I was attempting to reform, the nice big dial, and it not needing a battery or auto powering off inconveniently made it very useful!
Regards
Lloyd
Lloyd 1985 is online now
Old 11th Sep 2019, 11:57 pm   #9
Vintage_RC
Vintage_RC's Avatar
My one looks just like yours avocollector. I did a write up on the forum last year about some accuracy tests I carried out and the results were impressive for a 50 year old instrument. There is also a photo of mine showing the same pink colour. Here is a link if you want to take a look:-
https://vintage-radio.net/forum/showthread.php?t=149821
Alan G6PUB, BVWS
Vintage_RC is offline
Old 12th Sep 2019, 10:53 am   #10
WME_bill
Selectest 50. Mine is a nice light grey, with a dark grey terminal panel and a black back. No trace of a brown/geige or of pink. It is the PO 14C version, which may indicate some different manufacturing specification.
wme_bill
WME_bill is offline
Old 13th Sep 2019, 4:28 pm   #11
avocollector
Thanks to everybody for their contributions - it's definitely pink but it appears this was one of the original colours. I suppose it makes for added visibility on a test bench where most instruments would be grey or black. Intriguing though.
Old 13th Sep 2019, 5:12 pm   #12
wd40addict
wd40addict's Avatar
have both the Mkii (pink) and the Mkiii (grey). They obviously realised their mistake with the terminals and the later model has full depth 4mm sockets.
My Mkii probably hadn't been calibrated for years and the magnetic shunt needed a tweak as all ranges were reading low. Mkiii was fine.
wd40addict is offline
Old 14th Sep 2019, 10:22 pm   #13
avocollector
This thread brings me to another question people may know the answer to. Looking at the pics here of others Selectests they have mk II or mk III on the meter scale - but mine does not (see below). Does this mean it's earlier or later than the ones with the mk II or III inscriptions? thanks.
Old 14th Sep 2019, 10:36 pm   #14
turretslug
turretslug's Avatar
It'll be earlier than a MkII- the "blind" terminal posts are a pointer here, with older test leads tending to have hooked or forked ends to be clamped by the post in the same manner as older-type AVOs with non-4mm terminals. Also, it's quite common for the first version of anything not to be labelled "MkI" etc- designers and marketing folk don't like to create an implication that an improved version might be in the pipeline! Conversely, "MkII" of any product frequently gets trumpeted from the tree-tops. Looks as though this labelled-knob presentation that was replaced by the transparent plastic with underlying labels type in MkII and MkIII versions was reverted to in the end, perhaps because of the clouding problem mentioned earlier.
