Old 20th Jul 2018, 8:34 pm   #21
Pieter H
Default Re: Tuners in Philips G6-G11 CTV chassis
Hi Synchrodyne (post #19),
to be honest I have no clue (yet). In a sense it is very surprising to have Philips sets with rotary tuners as late as 1975 (K9 chassis). By then the standard sets were already at the third generation varicap tuners!
Assuming you're right, however, and that indeed by then still rotary tuners were used, I can only link this to the non-availability of a matching varicap tuner. Which could or could not have had to do with the IF changes in Australia. In the end it was a business decision to develop a specific derivative or not.
Again, some more detailed info about the actual tuner used in the Philips sets in Australia could help to narrow down the discussion.
Cheers, Pieter
Pieter H is offline
Old 20th Jul 2018, 8:38 pm   #22
Richard_FM
Richard_FM's Avatar
Originally Posted by Pieter H View Post
Richard (post #16),
no, as far as I can see there have never been dedicated Ireland tuners within the Philips tuner range. Just one general remark: the fact that I haven't seen them doesn't mean they never existed! New tuners keep on popping up regularly.
The best way to verify this would be a look inside some Philips sets made for Ireland and picture the tuner label. You never know! But as Peter and Kan_Turk already suggest, most likely it were standard Western-Europe VHF-UHF tuners.
Cheers, Pieter
Thanks, I couldn't think of too many other places that broadcast on VHF with a 6Mhz separation between sound & vision, South Africa & Hong Kong come to mind.
Richard_FM is offline
Old 20th Jul 2018, 10:36 pm   #23
kan_turk
kan_turk's Avatar
Just to elaborate slightly - specs for Philips VHF tuners of the era explicitly included system 'I' in the list of systems covered (systems B, C, D & I)
J
kan_turk is offline
Old 20th Jul 2018, 11:34 pm   #24
Synchrodyne
So far I haven't found any details that would help. There is a picture of an Australian K9 with rotary VHF channel selelctor at: http://troysvintagevideo.0catch.com/philipsk9tv.html.
The picture includes the front page of a servcie manual that is labelled "K9A", in which the "A" suffix might mean the Australian variant. On that page one may just make out that the VIF was 36.875 MHz, the later standard Australian value.
Cheers,
Synchrodyne is offline
Old 20th Jul 2018, 11:46 pm   #25
Synchrodyne
And South Africa did not use any Band I channels, but did use an upwardly extended (to 254 MHz) Band III channel set, as well as UHF. So it probably needed special or modified VHF tuners. Also, it used the CCIR standard 38.9 MHz VIF, not 39.5 MHz. Hong Kong practice in this regard I don't know.
The SAWF makers catered for a variety of IFs from the start. I have an early Plessey datasheet, undated - but the fact that it refers to the SL1430 IF preamplifier rather than the SL1431/2 is the “tell” - that includes the SW453 for South African system I with a 38.9 MHz VIF.
Cheers,
Old 21st Jul 2018, 2:45 am   #26
Synchrodyne
More on the Australian K9A at:
http://www.videokarma.org/archive/in...t-237987.html; and:
https://www.radiomuseum.org/r/philips_02kd254_k9a.html
The first suggests that the rotary VHF tuner was a locally-made unit.
Cheers,
Old 21st Jul 2018, 8:20 pm   #27
Pieter H
Interesting findings on the Australian Philips chassis!
The fact that the rotary tuner in the Australian K9A chassis had to use the new 36,875MHz IF meant that a "new" tuner had to be designed (Australian channels and IF). Given the date (10 years after the last known internal Philips rotary tuner design) makes it less likely this was a Philips tuner. At the same time it was customary to shift older models ownership to the more remote design and production centres, and as we know technologies have the tendency to live much longer than one expects. So it might equally well have been possible that some team somewhere designed the required new model. Only more detailed service info will tell us.
Cheers, Pieter
Pieter H is offline
Old 22nd Jul 2018, 1:04 am   #28
Synchrodyne
One possibility is that the tuner was simply carried over from preceding monochrome models. Philips Australia VHF tuners would have been “different” from that start, with the Australian channelling (inclusive of Band II and sub-Band III allocations) and the original 36.0 MHz IF. Adjustment to the 36.875 MHz IF was probably not a major operation – a slight change of local oscillator tuning relative to the RF tuning and a slight shifting of the tuning of the output coil, perhaps.
The Australian channelling might have been a bit of a challenge in the early varicap era, which in turn may have resulted in retention of rotary tuners for longer than was done elsewhere.
Judging by the K9A pictures found so far, it had an actual rotary tuner and not simply rotary switching of a varicap type. This is deduced by the apparent absence of the pop-out present drawer at the bottom of the control panel.
The following K9A-2 model had the regular K9 six pushbutton set for station selection. Presumably by the time it was released (1976-77?), varicap tuning covering all of the Australian VHF channels had been worked out.
Here is a picture of another K9A version, showing the rotary tuner: https://www.radiomuseum.org/r/philip...?language_id=2.
Cheers,
