21st Sep 2019, 1:31 pm | #1 |
Calculating rectifier diode PIV.
Is there a rule of thumb or calculation for ensuring the correct spec, IE PIV for a rectifier diode or bridge?
TFL, Andy.
21st Sep 2019, 1:52 pm | #2 |
Re: Calculating rectifier diode PIV.
1.4 x Vrms according to this http://www.valvewizard.co.uk/bridge.html
21st Sep 2019, 1:55 pm | #3 |
Vpeak in x 2 plus a margin.
Lawrence. |
21st Sep 2019, 1:55 pm | #4 |
That's what I've worked on in the past Paul, but having read a few threads and wotnot on PSU design I was under the impression this is incorrect, due to back EMF of the tfmr and suchlike.
Written before Lawrence's reply... So the peak Vin x 2 + a bit on the safe side. This brings us to what's marked on tfmr's, Vpeak or Vrms. i guess measurement of the AC waveform is the way to go. Andy.
21st Sep 2019, 2:03 pm | #5 |
Transformers with their voltages indicated or stated will indicate/state the RMS voltage, all AC voltages are RMS unless otherwise stated....
Regarding PIV, what I said was for bi-phase full wave. Lawrence. Last edited by ms660; 21st Sep 2019 at 2:29 pm. Reason: clarification |
21st Sep 2019, 2:19 pm | #6 |
Ok, down to specifics, I have a tfmr on the bench, sec is 330v 0v 330v. AC in 245v RMS on the 0v 240v pri taps, OP on one half of sec is 500v peak ( scope set to 20v/div = 5 divs, 10x probe, (5x 20) x 10). Lastly are tfmr specs usually given for loaded or unloaded? This tfmr says 330 etc @ 60mA, so I guess loaded, will load and check V out. Checked, with a 5500r load on centre tap and 330v, IE one half of total winding, I get 350v RMS, with load on the 330v 330v taps I get 337v RMS, about right.
So a diode with a PIV of 1200v would be about right, correct? I've been using ones rated at 800v PIV without issue, therefore why is 2x peak + a bit correct? Is it because the tfmr inductance back EMF? Lastly is this calc for the loaded rating or unloaded? Andy.
Curiosity hasn't killed this cat...so far. Last edited by Diabolical Artificer; 21st Sep 2019 at 2:27 pm. |
21st Sep 2019, 2:27 pm | #7 |
If it's a centre-tapped transformer with two diodes - let's say 100-0-100V RMS - feeding a capacitor-input filter then think like this:
The capacitor will charge with DC to the peak voltage - which is 1.414x the RMS - so it'll be sitting at 141V Then on the next half-phase the end of the winding will go to a peak-negative of 1.414x the RMS - in other words -141V. So the diode is seeing 282V worst-case voltage difference across its terminals. To leave plenty of "wiggle-room" to handle transients etc. I would prefer to specify a diode rated at 4x the transformer RMS voltage, though some people will specify a lower rating and then fit transient-suppressors etc. Bridge-rectifiers - since there are essentially two diodes in series at any one time - are more forgiving. |
21st Sep 2019, 2:31 pm | #8 |
Thanks G6, 4x tfmr RMS rating, in this case 330 x 4 = 1320v, so not far off Lawrences peak x 2 + tad. "Is it because the tfmr inductance back EMF? " Transients, gotcha.
Andy.
21st Sep 2019, 3:10 pm | #9 |
Andy, scroll down to pages 8 and 9 to see the PIV the diodes are subjected to for the different rectification regimes:
https://www.ietlabs.com/pdf/GR_Appno...r%20Design.pdf Lawrence. Last edited by ms660; 21st Sep 2019 at 3:15 pm. |
21st Sep 2019, 3:38 pm | #10 |
Two 800V diodes in series should give adequate protection. I agree that a single 800V diode is pushing things a bit for 330-0-330.
21st Sep 2019, 4:05 pm | #11 |
Thanks Paul, that's what I've done.
Andy.
