17th Sep 2019, 2:39 pm | #1 |
No Longer a Member
Panasonic SG-2070L
Does anybody have much experience of the turntables on these lovely old music centres?
I have had mine for many years with very, very few problems up until the other day when I went to use the turntable. When I try to lift the tonearm with the cueing lever it doesn`t lift high enough to clear the surface of the record (I found out the hard way!), but when the auto return mechanism is going through it`s paces it lifts the tonearm as it should, so I`m sure this is a problem with the lever mechanism itself. Just looking for any pointers/advice on this before I remove the deck and delve underneath. I`ve got a horrible feeling something has snapped or broken as this has happened suddenly, and not over a period of time. Many thanks all |
17th Sep 2019, 7:04 pm | #2 |
Re: Panasonic SG-2070L
If it’s something broken then it should be obvious. It might just be sticky grease stopping the lift working.
17th Sep 2019, 9:54 pm | #3 |
I'd start by checking the service manual for the deck, to see what parts are involved. A picture tells a thousand words!
Regards, Ben. |
