Old 12th Sep 2019, 1:01 am   #1
Sinewave
Sinewave's Avatar
Default Capacitor leakage tester
Since the best way to test capacitors is testing for leakage, I wonder if anyone here either has a good leakage tester for sale or some drawings for a good home brew leakage tester? Thanks.
Avometer, vintage Fluke and Marconi collector.
At 144-146.00Mhz, keeping one wavelength apart.
Sinewave is offline
Old 12th Sep 2019, 1:53 am   #2
suebutcher
suebutcher's Avatar
Default Re: Capacitor leakage tester
From my notebook, here's a quickie design for testing high voltage capacitors at 100V and 200V using junk box parts. I later modified it to give an extra 50V range using the secondary centre tap. The "short" function is to discharge the capacitor after testing or reforming, only to be used with the meter off!
The Waves That Rule Britannia
suebutcher is offline
Old 12th Sep 2019, 6:23 pm   #3
sven_swe
sven_swe's Avatar
I built the same as discussed in this thread and it works really well:
https://www.vintage-radio.net/forum/....php?p=1077022
Also I might have a Heathkit IT-11 capacitor checker for sale, it's a very nice unit. It's a 110V but a step-down transformer comes with it.
sven_swe is offline
Old 12th Sep 2019, 7:32 pm   #4
Electronpusher0
Originally Posted by sven_swe View Post
I built a modified version of this tester, see post 10 of the thread. It's still working very well.
Peter
Electronpusher0 is offline
Old 12th Sep 2019, 10:04 pm   #5
Sinewave
Sinewave's Avatar
Thanks guys, I shall take a good look.
Sinewave is offline
Old 13th Sep 2019, 3:01 pm   #6
Diabolical Artificer
Diabolical Artificer's Avatar
There's this one I built , see attached. I used my variac to get rid of the divider chain, the thing fitted into a 3" x 2" x 1" deep box. I use mine with one meter to monitor current, another voltage. As a good cap should have a linear dialetic resistance, if you put 350v on the CUT, you should see 35uA or similar leakage. Once used a few times you get a "feel" for a bad cap by the readings of the ammeter and voltmeter.
Andy.
Old 13th Sep 2019, 3:12 pm   #7
Sinewave
Sinewave's Avatar
Andy.
Thanks, will take a look into that.
Sinewave is offline
Old 13th Sep 2019, 7:35 pm   #8
AC/HL
AC/HL's Avatar
Two posts contravening forum rules deleted.
Bill, BVWS member
AC/HL is online now
Old 15th Sep 2019, 2:35 pm   #9
Sinewave
Sinewave's Avatar
Sorry if that was me. If you let me know what it was I can make sure I don't make the same mistake again if it was my post. From memory I was responding to an 'item available post' in this thread.
Sinewave is offline
Old 15th Sep 2019, 2:46 pm   #10
AC/HL
AC/HL's Avatar
There was a political inference in them. We're very strict on this at this critical time.
Bill, BVWS member
AC/HL is online now
Old 15th Sep 2019, 4:02 pm   #11
Sinewave
Sinewave's Avatar
That's fine, thank you for letting me know.
Sinewave is offline
Old 17th Sep 2019, 6:41 pm   #12
Sinewave
Sinewave's Avatar
Andy.
Did you still use a transformer? I'm not sure I have a 1:1 transformer here, I've got a load of others hanging around though.
Sinewave is offline
Old 17th Sep 2019, 9:21 pm   #13
Ed_Dinning
Hi, my homebrew design uses a small 0.5A variac and a 240/650v transformer, so can test up to 1000V and is isolated.
Metering on output and range switching for accuracy, also a dump circuit to discharge the cap at turn off , plus protection diode for the mA meter against reverse current when switching off.
2, charge resistors fitted, both quite high wattage so I can do a leakage test or run a reform cycle.
I'll post the circuit when I find it.
Ed
Ed_Dinning is offline
Old 18th Sep 2019, 6:58 am   #14
"Did you still use a transformer?" Variac and iso tfmr. "2, charge resistors fitted, both quite high wattage so I can do a leakage test or run a reform cycle" That's a good idea, the one in the "Big Bang" is ok for reforming HV low value caps, but not for high value low voltage caps, mind, I use a bench PSU for those.
Andy.
Old 18th Sep 2019, 11:05 am   #15
Sinewave
Sinewave's Avatar
What's the maximum voltage and capacity you'd say this tester is fine for?
Sinewave is offline
Old 18th Sep 2019, 1:26 pm   #16
With my variac 750v.
A.
Old 18th Sep 2019, 2:09 pm   #17
Ed_Dinning
Hi Mine will go up to 1000v and capacitance is only limited by charging time. This could be adjusted with a change of series resistor value.
Also built into the case is an ESR meter.
Ed
Old 18th Sep 2019, 2:47 pm   #18
Sinewave
Sinewave's Avatar
Thanks guys. This certainly sounds like something I need to build.
Sinewave is offline
Old 19th Sep 2019, 7:32 am   #19
Here's a pic of mine.
A.
