Old 25th May 2020, 9:01 am   #1
Chris55000
Default Cossorscope 1076 80MHz model?
Hi!
In the back of my "Radio And Electronic Laboratory Handbook", first 1961 edition with a yellow dust jacket, in the advertisements at the back, there's an advertisement for an 80MHz "Cossorscope Model 1076"–
https://books.google.co.uk/books?id=...201076&f=false
Pages 561 and 562 of this:–
https://archive.org/details/in.ernet.dli.2015.16346
Does anybody know anything about this and has any bookwork ever surfaced about this model?
It looks to be clone of a Tek 547a or similar, it's advertised as having the same "beam direction indicator" neons as the Tek models have!
Chris Williams
Chris55000 is offline
Old 25th May 2020, 9:07 am   #2
cmjones01
Default Re: Cossorscope 1076 80MHz model?
Curious. Looks like a re-imagining of the Tek 536 X-Y scope but with higher bandwidth. I like especially the "light weight, only 104lb" claim!
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline
Old 25th May 2020, 10:46 am   #3
Boulevardier
Chris
104 lb - Gordon Bennett! That's only 6lb less than a DST100! So it's very much a two-man-carry job.
Mike
Boulevardier is offline
Old 25th May 2020, 10:56 am   #4
Cobaltblue
Cobaltblue's Avatar
Hi Chris
Perhaps you could find out about my Cossor 1059
Pictures in #6 of threat below
https://www.vintage-radio.net/forum/...ighlight=Scope.
It predates the 1076 but also has a number of features including weight!
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 29th May 2020, 8:00 pm   #5
Cobaltblue
Cobaltblue's Avatar
I had a look in my Cossor test equipment folder couldn't find the 1076 scope other than advertising material but did find the handbook for the 1083 Plug in.
I may still more, I have hundreds of unsorted documents
the 1083 is described as a Calibrated delay unit for the 1076
If the document follows other Cossor document numbering its dated 1961
Mike T
Name:	Cossor 1083 1.jpg
ID:	207150   Click image for larger version
Name:	Cossor 1083 2.jpg
Mike T BVWS member.
www.cossor.co.uk
