22nd Mar 2019, 7:26 pm | #1 |
Pye FM set just white noise...
Hi All
A piano key 1203 radiogramophone, worth improving, and tolerated by the g/f in her living room as it supports a colony of china fairies (other group noun suggestions welcome !). On vhf there's only white noise and no stations. I presume then that the I.f. is okay. Is there anything can be inferred by this ? The solid state decoder maybe ? Coincidentslly dead on a.m too... Advise most welcome Thanks jm. |
22nd Mar 2019, 8:26 pm | #2 |
Re: Pye FM set just white noise...
Dirty wavechange switch?
ECC85 are renowned to not last long, and possibly a second fault in the AM section. Open HT dropper resistor. Check all the voltages for a start. David
22nd Mar 2019, 8:29 pm | #3 |
This radiogram is very unlikely to have a solid state decoder (or any decoder for that matter) unless someone has attempted a modification. Have you connected an external FM aerial? This needn't be anything elaborate...a piece of wire a few feet long will do for starters if you are in a reasonable FM reception area...don't expect first class results with this though...it's just to establish if the radio is actually capable of working. You can make up a better aerial later.
Has it been overhauled or serviced? Chances are the pushbutton assembly will need a good clean and if not already done, a number of capacitors will require replacement.
22nd Mar 2019, 9:11 pm | #4 |
Basic chassis, no decoder.
Service sheet here: https://www.service-data.com/section.php/6472/1/1203 |
22nd Mar 2019, 11:34 pm | #5 |
Thanks chaps there is no eabc80, therefore solid state.
Will try the ecc Jm |
23rd Mar 2019, 8:56 am | #6 |
The only solid state items are the diodes for the AM and FM demodulators. No decoder. The ECC85 is a possibility so try that first.
23rd Mar 2019, 10:02 am | #7 |
If you have white noise, the audio stages must be working, does it work on the gram setting if you tap the cartridge with the volume up? Both left and right channels?
You say dead on AM as well? The ECH81 is AM mixer/oscillator and FM 1st IF amp as well so if that is duff you will lose both. Put it on AM and an AM transistor radio next to it. Sweep the tranny through the same waveband, any squeals and whistles? After that its EF89 as common 2nd IF amp and then EF80 which I think is only on the FM detector. Last edited by Boater Sam; 23rd Mar 2019 at 10:26 am. Reason: Added. |
