13th Aug 2008, 9:20 pm | #1 |
Hacker Sovereign II
Hi all
I think this is the correct section for this...so here goes. I went down to the town tip today to dispose of some dead PCs and other bits and pieces. While putting the items in, I turned round and there at the side of the container was a Hacker Sovereign II. It appeared intact although extremely dirty and paint marked. I grabbed it and dropped it into the boot of the car as I went for the next load to dump. On getting it home I've had a quick look inside. The insides are very clean and look completely untouched. The only obvious problem is that one of the batteries has leaked and has destroyed the associated battery connector and has caused some corrosion of the rear hinge. The date code on the batteries is 1999. There is a slight discolouration of one of the output transistors which looks like it may have been overheating. Outside, apart from the dirt, all is complete including the aerial and it has a full complement of knobs. The only obvious defect is that the rexin type material is peeling from the handle. The rest of the covering is intact and is still taut. The turntable is present although it has a small piece broken from the outer edge. What a lucky find. I remember these radios in their heyday whwn they were new. They were quite expensive then and were considered to be pretty upmarket sets. I seem to remember that they sounded rather good too. What is everyone's opinion of these sets? TimR
All those moments will be lost in time, like tears in rain. |
13th Aug 2008, 9:26 pm | #2 |
Re: Hacker Sovereign II
Very nice! All Hackers are, and you have picked up a good one there. You can get a PP9 clip and clean that hinge off and then try it.
Some have the AF117 problem, but apart from that its a few caps and you're away. Lucky Josser.... Cheers, Steve P.
13th Aug 2008, 9:30 pm | #3 |
Hi Steve
I thought I remembered them having AFxxxs but this one doesn't seem to have them. The transistors look like silicon types...they're small black plastic ones. TimR
13th Aug 2008, 9:31 pm | #4 |
Well, I think they're one of my very favourites. The sound they produce is superb for something so small, on all wavebands.
Faults are rare, but those that come to mind are:
Nick. |
13th Aug 2008, 9:41 pm | #5 |
Hi Nick
Great to hear from you... Actually, its not that small a set and it has an 8 x 5 speaker in it. It's one of the chunky sets. It measures 12" x 8" x 5" deep. TimR
13th Aug 2008, 9:57 pm | #6 |
14th Aug 2008, 8:17 am | #7 |
Well spotted, Tim!
The RP25B is a superb set, and indeed does not have the infamous AF* transwhiskers. Mine, which is playing as we speak (!) is a few feet away from me, and you can see it here.
Mike. |
14th Aug 2008, 9:54 am | #8 |
Hi Mike
Yup...that's the one. I'll take some pictures before I clean it up. Then I'll have to try and crack posting pictures on the forum. I'll also check the electrolytics that both you and Nick mention. I'm glad I spotted the radio. This type of good fortune often seems to happen to others. However, I can no longer complain (probably won't stop me though). TimR
14th Aug 2008, 10:57 pm | #9 |
Hi all
Update on above radio... It doesn't work...damn!! All I get is a couple of very faint stations on MW and nothing on either FM or LW. There is a quiet hiss from the speaker with the volume fully advanced showing activity in the AF stages. I reckon it might be an IF fault. Ho-hum. Onward and upwards. Better start checking voltages and such like. TimR
14th Aug 2008, 11:07 pm | #10 |
Never mind and don't worry!
Check and clean the buttons on top. Make sure all contacts are clean and of course check all wiring. Common problem. If that does not cure it, I'll get the manuals out! Cheers, Steve P.
14th Aug 2008, 11:09 pm | #11 |
Shame, although that is always the risk of getting stuff from the tip.
I saw a good looking TV in one the other day, but not knowing if it was completley ruined under the surface put me of. |
14th Aug 2008, 11:14 pm | #12 |
I bet it's those big electrolytics dragging the volts to the tuner/IF stages down.
Try replacing C21 (350uF). Have you got the manual? It's just as nice as the set it! P.S. I think some of these DO have AF117s N. |
14th Aug 2008, 11:19 pm | #13 |
Hi Nick
That might well be the problem. The IF amp isn't doing much and low voltage could easily stop the VHF oscillator. Where about, physically, are the capacitors? Most of them seem to be the blue Mullard type. Unfortunately I don't have the circuit/manual. TimR
15th Aug 2008, 8:24 am | #14 |
Tim
C21 is at the top of the board just under the VC/On-off switch. Nick is right about the earlier AM IF strip having germanium transistors - in that case, there is C16 (250 mfd) to suspect as well. Worth getting a manual from Paul Stenning in the usual way - it's quite a weighty tome -34 pages. There were a few changes and mods to the design.
Mike. |
15th Aug 2008, 8:43 am | #15 |
I grew up with one of these in the Kitchen .Its in Mums attic . I keep thinking about raiding the attic for it then dont . I have also just been given another last week from where i was working ,along with two smaller ones ones Autocrat mk2 among them .The least attractive seams to be factory covered in fablon.
I remember Mums set has a fault .and I believe the other 3 do to |
15th Aug 2008, 12:10 pm | #16 | |
Nick. |
15th Aug 2008, 2:06 pm | #17 |
Yes - the model number, RP25, RP25A or RP25B, is at the bottom right hand corner of the control panel. Only early RP25s have germanium IF transistors, that change came a while before the RP25 was supplanted by the RP25A: then the -B version unlike its predecessors uses an IC on its FM IF board.
Paul |
