24th Aug 2008, 10:38 pm | #21 | |
Re: Pye 15a problem
And what does C28 do in the set... As far as I can see the wires seem to be in suprisingly good condition although it is probably best to change them anyway. Looks can be deceiving. |
24th Aug 2008, 10:55 pm | #22 |
Re: Pye 15a problem
C28 is a mains filter cap. It should be replaced with an X2 cap as these are built in such a way as to fail open circuit.
I'm afraid I just cut it out.... C2 is best left where it is as it affects the earthing of the set. If C20 is removed, the set won't accept a pick up. No real problem in removing this. Cheers, Steve P.
27th Aug 2008, 1:54 am | #23 |
Re: Pye 15a problem
Firstly I will say thank you very much everyone for all of your help.
Where would be a good place to find these replacment parts, and how simillar will a x2 capacitor be cosmeticaly to the original. The ones I found seems to be rectangular rather than cone shaped as the original is. |
27th Aug 2008, 9:22 am | #24 |
Re: Pye 15a problem
Well the BVWS do some parts, you can get parts at meets, or click here - http://www.vintage-radio.com/contacts/links.html .
I use Past Times Radio, but not related, etc. Cheers, Steve P.
27th Aug 2008, 10:21 am | #25 | |
Re: Pye 15a problem
What I tend to do is disconnect both ends of the old component, and either remove it or leave it in place "for originality" if it's held to the chassis with a metal clip as they sometimes are. Then, I simply solder the new component to the switched L and N terminals of the on/off switch. See here (the filter cap is the blue component): https://www.vintage-radio.net/forum/...7&d=1200063483 Nick. Last edited by Nickthedentist; 27th Aug 2008 at 10:26 am. |
