Old 16th Jun 2008, 10:14 pm   #1
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Question Garrard SP25 MkIII
Did the above come with an 'umbrella' spindle? There is no way it can automatically START to play a record without one, yet the speed selector is marked '78/10" -45/7" - 33/12" - 33/7".
'LIVEWIRE?' is offline
Old 16th Jun 2008, 10:26 pm   #2
Tom_I
Tom_I's Avatar
Default Re: Garrard SP25 MkIII
No, it's a single play turntable.
You place the record on the platter, and set the size and speed using the control on the right. Then flick the front control to 'auto' and release. The turntable starts, and the arm lifts, moves out and sets down to the specified position, then at the end of the disc it automatically lifts and parks, and the turntable stops.
Tom_I is offline
Old 16th Jun 2008, 10:33 pm   #3
Dave Moll
Dave Moll's Avatar
And presumably you would have to start a 12" 78 manually, as that combination is not included in the settings.
Dave Moll is offline
Old 16th Jun 2008, 10:39 pm   #4
Tom_I
Tom_I's Avatar
Yes, it's odd that. The vast majority of classical 78s were 12 inchers, and yet it has a setting for 7-inch 33s, which I wouldn't have thought were all that common.
Tom
Tom_I is offline
Old 17th Jun 2008, 8:27 am   #5
Michael Maurice
Michael Maurice's Avatar
Tom
7" playing at 33 was more common than you think, two big hits of the 70's spring to mind, Mungo Jerry's in the Summertime was No 1 for 8 weeks over June/July/August 1970 and Clodagh Rogers Jack in the box in 1971.
I would think these decks which were popular in the early 1970's (I bought one in 1972) were designed to be used in systems bought by the young people of the day.
Classical 78's wouldn't have been popular then, classical listeners would have almost certainly replaced their 78's with LP's.
Michael Maurice is offline
Old 17th Jun 2008, 10:17 am   #6
'LIVEWIRE?'
Tom I - Could there be a problem in the mechanism? Having cleaned of dried grease and ensured that, amongst other things, the cam gear and its associated levers are operating correctly, if I place arecord on the T/T, set the speed & size to suit, then flick the control to 'Auto', all that happens is that the PU Arm lifts from the rest, moves slightly, then the unit switches off, returning he arm to it's rest. If I play a record of any speed or size manually, the auto stop works correctly, returning the arm to it's rest & switching off at the end of the record.
Old 17th Jun 2008, 2:47 pm   #7
ben
ben's Avatar
Originally Posted by Michael Maurice View Post
7" playing at 33 was more common than you think, two big hits of the 70's spring to mind, Mungo Jerry's in the Summertime was No 1 for 8 weeks over June/July/August 1970 and Clodagh Rogers Jack in the box in 1971..
In several decades of record collecting, I've only ever seen the mungo jerry single at 33, plus a few cheap EPs on the avenue label, maybe one or two others so I wouldn't say 7" at 33 is common by any means.
In Argentina however, all the singles are at 33...maybe Garrard were looking at that market at the design stage? In south america they were widely sold as Gradiente.
getting back to the sp25 mkIII at hand, My 40b is basically identical but has the overarm of the 2025. I'm sure if you put a step spindle in the sp25mkIII it would react since the mechanics are the same.
In this case, it sounds like something is not being activated off the main cam. Time to look under the deck - missing spring?
-ben
ben is offline
Old 17th Jun 2008, 4:33 pm   #8
Tom_I
Tom_I's Avatar
Yes, something's not right. When you try to start the deck in auto mode, it's performing a 'stop' rather than a 'play' cycle.
I'm not sure with these how the deck 'knows' which to do. With autochangers of similar design, it's the vertical position of the control arm (the one that sits on the records stacked on the spindle) which performs this function. If it's sitting in its lowest position (i.e. no records on the spindle) a 'stop' cycle is performed, while if it is raised above this then a 'play' cycle is carried out. It's obviously different in this case, as there is no overarm.
I'm sure somebody on the forum will be able to help.
Tom
Tom_I is offline
Old 17th Jun 2008, 4:49 pm   #9
geofy
Post Re: Garrard SP25 MkIII
Without knowing to much about these decks, apart from it being capable of very good results with a magnetic cartridge (and fitted with either a stylus suitable for microgrove 33 1/3/45 or a larger stylus for 78s) I would guess that the auto start has to push a lever into the central cam to initiate the start up. This action seems to be missing, possibly because of a stuck lever, the underside of the deck should be looked at while pressing the auto start lever.
I had a similar problem with a TC2025 deck in a Bush SRP51 that would not lift at the end of record, it was due to a seized bush within a bush, it had to be prised apart and then re-greased, it has worked well ever since.
Geof
geofy is offline
Old 18th Jun 2008, 12:21 am   #10
Michael Maurice
Tom
IIRC the deck 'knows what to do because the cam is started by the off/on/auto lever, rather than the trip pawl, I may be wrong, its 35 years since i last saw one.
Old 18th Jun 2008, 12:26 pm   #11
Tom_I
Tom_I's Avatar
I thought that too, but you can reject the disc by flicking the lever to 'auto' while it's playing, and it then performs a 'stop' cycle, so it can't be as simple as that.
Tom_I is offline
Old 18th Jun 2008, 12:55 pm   #12
julie_m
Is the deck perhaps responding to the position of the tonearm WRT the rest position, rather than the height of the steadying arm, to decide whether to start or stop?
BTW, watch out for SP25s that have been fitted in disco consoles! This was a very popular deck for this application (BSRs weren't up to the job), but they were usually converted to full manual operation by removing part of the trip mechanism.
julie_m is offline
Old 18th Jun 2008, 6:38 pm   #13
Stewart
Stewart's Avatar
Unlike their autochanger brothers, I don't think these decks do "reject" when set to AUTO..I pretty sure that function only ever re-starts a record on the SP25. The fact that the arm returns at the end of the record and that it does its futile dance above its rest when trying to start proves the ttrip and cam mechanism is complete and operational.
I would focus on what is triggered / moved differently between the arm triggering the trip mechanism and cam (at the end of a record) and what is activated in addition to the cam /trip mechanism when the operation lever is moved to auto. The mechanical difference should lead to the cause of the problems.
Stewart is offline
Old 18th Jun 2008, 7:01 pm   #14
Tom_I
Tom_I's Avatar
I was going by the user manual, which says that the deck will reject and stop if 'auto' is selected when playing. Reality could prove otherwise, of course.....
Tom_I is offline
Old 18th Jun 2008, 7:26 pm   #15
'LIVEWIRE?'
The fault seems to have been caused by too much friction in a pivot underneath the chassis. Automatic play operation is now OK, though I haven't tried rejecting a record part way through playing
Old 18th Jun 2008, 9:15 pm   #16
Stewart
Stewart's Avatar
Tom_I - that's interesting.. I'm not going to disagree with the manual! Certainly the SP25 on my Hacker doesnt seem to reject in the traditional sense - although starts and stops as expected otherwise!
Sounds like the problem Livewire had was down to sticky grease once more.. pleased its sorted.
Stewart is offline
Old 18th Jun 2008, 9:39 pm   #17
humorist2751
Greetings to all.
Having had one of these decks virtually for ever (well, since circa 1973 anyway), I can tell you that the "Auto" position has a dual function.
To begin play, slide the control lever all the way to the right until it latches, and the deck will set the arm down at the programmed point (7, 10, or 12 inches as appropriate).
To reject a playing record (i. e. to stop it prematurely), the action is similar - but you must only momentarily have the lever at the "Auto" position; pull it back to "manual" by hand, thus releasing the latch and aborting the remainder of the autostart sequence. The result is that the arm will return to the rest and the deck will stop.
Hope this makes things clear - the manual has more.
Regards
David F. Symes
humorist2751 is offline
Old 18th Jun 2008, 9:47 pm   #18
ben
ben's Avatar
manual here btw.
ben is offline
Old 18th Jun 2008, 9:51 pm   #19
Tom_I
Tom_I's Avatar
Yes indeed. I don't think I've ever used a Mk III, but here's the bit from the manual.
Tom_I is offline
