Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
24th Mar 2006, 6:04 pm | #1 |
Murphy 405 line generator HELP!!!
Hi guys,
I just got this off fleabay and its a bit dead... I opened the PSU and found that the Mains transformer over many many hours ofrunning has decided t leak all of its wax and so has the smoothing choke. Is there any way of fixing this. I have no clue to the voltages its supposed to give nor the currents. Pics of the affected transformer enclosed... Andi
33, 45, 78, around and around they go...
24th Mar 2006, 6:46 pm | #2 |
Re: Murphy 405 line generator HELP!!!
Hi well I would say your transformer looks cooked, have you a model number for this item? as one of us may have a circuit regards Den
24th Mar 2006, 6:50 pm | #3 |
What a mess
However, if the transformer is still OK electrically, all might not be lost. "Migration" of wax and pitch from transformers doesn't necessarily mean they won't work, although obviously it's a sign that they've run far too hot. Removal of the excess wax (hairdryer and plenty of old rags), then eliminating the cause of the hot running (e.g. shorted supply line, leaky coupling caps) has worked for me on several occasions (e.g. my Hacker Mayflower I radio). Nick. |
24th Mar 2006, 7:04 pm | #4 |
Hmmm model number ...
Well its a Pattern Generator type II by Murphy. and the PSU is Type A Andi
24th Mar 2006, 7:06 pm | #5 |
I must admit to having not tried powering it up as I know some of the caps need changing and if its gotten that hot (looks like its been a long tim in happening tho) then I am guessing its shorted someplace...
There is also a 2A fuse missing.. Andi
24th Mar 2006, 7:07 pm | #6 | |
24th Mar 2006, 7:17 pm | #7 |
I get a resistance of 5.5R on the primary winding
Its not showing any continuity to any of the secondaries
24th Mar 2006, 7:23 pm | #8 | |
Time to track down the service data, and then a replacement transformer, I fear Nick. |
24th Mar 2006, 7:32 pm | #9 |
Something tells me one may be easier than the other.. and that this may not be a viable restoration...
Andi
24th Mar 2006, 8:17 pm | #10 |
Is it a model TPGII ? Four chassis with following valves :-
Lock chassis : ECC34 + 6D2 RF Unit : 6L18 + 6F33 Power Unit : GZ32 Modulator chassis : 12(!)*ECC34, 6 * 6F13, 4 * 6D2 ? In which case I have both the service manual and the user manual. Also with that many heaters it is going to be quite some transformer and a primary measuring quite low ohms wouldn't suprise me. And the secondary winding that powers all them ECC34's must be pretty thick, I can't believe it'd go o/c. I wouldn't write off the transformer just yet, I had a fergy radio which must have emptied it's entire wax content all over the bottom of the cabinet yet that part of the radio worked fine. Pull out the valves and connect to the mains via a lamp limiter before condemning it. TTFN, Jon |
24th Mar 2006, 9:07 pm | #11 |
I think Mine is a TPGII
The exact item code on the front reads Murphy Radio Ltd TELEVISION PATTERN GENERATOR TYPE II NO 4238/1041 And the PSU is seperate. MURPHY RADIO LTD POWER SUPPLY TYPE A SERIAL NO. 4229/1041 I think maybe its similar to what you have the manuals for. I think I counted 13 ECC34's in there, thats a lot of valves... Andi
24th Mar 2006, 9:09 pm | #12 |
Jon,
Mine is 2 seperate units but the valve lineup sounds very similar. I cant be far from you is there any chance I could be cheeky and ask to borrow the service/users manuals please? Andi
24th Mar 2006, 9:31 pm | #13 |
Hi Jarl, all may not be lost as the tranny could be replaced with a different type if it is not important to keep chassis originality.
The HT current may be quite low 50/100mA at possibly only 250 V. Heater transformers for 10A at 6.3 V can also be found fairly easily. There is always a re-wind but that could be more expensive. HTH Ed |
24th Mar 2006, 10:00 pm | #14 |
I have an absolutly monsterous tranny out of a Yaesu FTdx401 Tranciever.. But need to find out what secondaries I need first
I dont think a rewind would be viable... I dont think the kit is worth that much is it? Andi
24th Mar 2006, 10:53 pm | #15 |
Hi Andi,
I note the vendor listed it as working - perhaps it was, even if overheating. I would remove the surplus wax, replace the power supply capacitors and run it solo, bringing it up slowly on a variac, monitoring HT output (if any) as you go. I have often seen this sort of situation in valve amplifiers, usually due to smoothing cap failure. The trannies are often OK when the fault is sorted. Good luck! I was watching this myself, but could not have justified a 300mile round trip to collect it. Do Pattern Generators often turn up at the NVCF? regards, Jerry |
24th Mar 2006, 11:00 pm | #16 |
Hi Jerry
Oh it was certainly a great journey as I ended up with most of the contents of the tv shop... but it hadnt been tested... I dont yet have a variac, thats my next purchase... Andi
