26th Jun 2011, 6:24 pm | #21 |
Re: Philips N4506.
It does sense effective reel size - there's a detailed circuit description from page 5 onwards in the manual.
Do you need a link to it ? could be you've got some aging caps in there as the circuit relies on certain caps charging and difference between the voltage coming off the supply motor as a generator and the voltage supplied to the driving (be it RW or FF) motor Last edited by MikeyPP; 26th Jun 2011 at 6:29 pm. |
27th Jun 2011, 4:44 am | #22 |
Re: Philips N4506.
thankyou, you simplified what i meant to ask, i thought i was on the right rails with the relation between take up and supply reel speed, yourre a great help, i appreciate i have asked a lot about this machine, i am still in the trade refurbing lcd tvs but these machines are as tricky as the tvs, and yes, a link would be appreciated, tricomp kindly sent one but i opened it and didnt save it, many thanks all, although on reflection i checked the motor voltage on the leading motor during ff\rw and it was approaching 20v, i wont bother you again until ive read the manual
thanks tony walker |
27th Jun 2011, 8:04 am | #23 |
Re: Philips N4506.
PM'ed
27th Jun 2011, 1:31 pm | #24 |
Re: Philips N4506.
27th Jun 2011, 2:19 pm | #25 |
Re: Philips N4506.
thank you mikey and james, i got the manual and sorted the rewind\ff issue out, a couple of caps were high in value, now it flies, there seems to be 3 autostop devices, the metallic strip, if present, the tension arms and some new one on me, when the tape has only a few feet left the relationship between the spools is detected and slows the tape right down to almost stop and then the stop function occurs, maybe this a function that shouldnt happen, but the speed deacceleration is rapid when it has almost rewound, i used the correct value caps, you have been so helpful, any chance of a user guide, please?
thanks again all tony walker |
4th Jul 2011, 3:20 pm | #26 |
Re: Philips N4506.
sorry, one last request, i formatted pc and forgot to save service manual, any kind souls please, thankyou
tony walker |
4th Jul 2011, 4:05 pm | #27 |
Re: Philips N4506.
4th Jul 2011, 7:15 pm | #28 |
Re: Philips N4506.
thankyou
