Old 27th Aug 2010, 10:55 am   #1
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Default English Language Service Data for Philips N4418 required
I have a manual for this R to R Tape Recorder-however all the instructions are in German. Does anyone have any Service Data in English for this model, please? - in particular relating to the speed control circuit. For some reason,if the 4.76cm/sec(1.875"/sec.) speed is selected, the machine can only be adjusted to run at 9.5cm/sec.(3.75"/sec.)and I haven't been able to find out why. The speed selector switch is operating correctly, so I presume there is a fault in the control module.
'LIVEWIRE?' is offline
Old 27th Aug 2010, 11:06 pm   #2
AC/HL
AC/HL's Avatar
Default Re: English Language Service Data for Philips N4418 required
I have some old Philips manuals, including the 4418, which I'll never need.
If you PM your address I'll pop it in the post, for the cost of the postage.
Regards, Bill
AC/HL is online now
Old 28th Aug 2010, 12:06 am   #3
cmjones01
If there's a particular part of the manual you'd like to understand, I'd be happy to have a stab at translating it if you can post a scan.
cmjones01 is offline
Old 28th Aug 2010, 10:07 am   #4
'LIVEWIRE?'
Bill, thanks-PM on it's way. CMJ-thanks for the offer-mainly I need to fully understand the
adjustment procedure, although I've traced out the speed control circuit in detail meanwhile, and now have to find out the cause of an intermittent fault in that department.
I may take up your kind offer if Bill's manual doesn't sshed any further light on the subject.
Old 29th Aug 2010, 12:02 am   #5
DIN Plug Pete
I seem to remember that I had this speed fault a few years ago. If my memory serves me correctly, it was just after I changed the capstan belt and it turned out to be something to do with the positioning of the pulley/pulse pick-up head. Sorry, but I can't remember exactly what I did, but it might point you in the right direction.
Peter.
DIN Plug Pete is offline
Old 29th Aug 2010, 11:19 pm   #6
'LIVEWIRE?'
Thanks for the tip, Pete. I'll check that when I'm back in my workshop.
Old 2nd Sep 2010, 8:45 pm   #7
'LIVEWIRE?'
Peter, I've set the position of the pulse pickup head as close to 0.1mm from the rotating magnet rim as I can determine and still have the problem. In the meantime I now have a detailed English Language Manual, courtesy of Bill(AC/HL), and will persevere with the 4418
in the hope that I can track down the source of the fault
Old 8th Apr 2011, 5:47 am   #8
cyclone
Does anybody out there have an English service manual for a Philips N4418?
Please PM. Thank you.
cyclone is offline
