Old 17th Jan 2014, 1:08 pm   #1
FERNSEH
FERNSEH's Avatar
Default 525 line NTSC into 405 line converter.
Just a fun thing. I connected my 405 line store converter to a NTSC 525 line video recorder to observe what the results would be like.
The 525/60 NTSC system has a line frequency very close to 625/50 system so there was no problem locking up the converter's main clock pulse generator. As the field frequency is 59.94Hz the theoretical line count of the converted picture should be 339. The clock pulse generator is running at 10.195784Mhz so after division of 1000 the 405 line frequency is 10.195794Khz which after dividing by the field rate of 59.94/2 results in a coarse 170 line uninterlaced picture.
There is also a curious 10Hz movement of the raster. Nevertheless the pictures are watchable.
DFWB.
FERNSEH is offline
Old 17th Jan 2014, 1:16 pm   #2
Karen O
Default Re: 525 line NTSC into 405 line converter.
Wow! Your converter must be very flexible to cope with that.
My converter would probably lose lock and put out nonesense, and maybe cause the attached TV to catch fire
I'm back to working on my converter again. I just have to synthesise the 405 line frame synch waveforms. There's nothing clever behind this, just carefully cycle counted 'bit banging' code.
Karen O is offline
Old 17th Jan 2014, 1:35 pm   #3
FERNSEH
FERNSEH's Avatar
The main clock pulse in this generator in this converter operates at 648 X 15,625HZ = 10.125Mhz. This high frequency is supplied to the address counters for the write function. A different frequency for the read function.
The same 10.125Mhz is first divided by four and then 250 to create the reference for the 405 sync and blanking generator.
There is a mathematical relationship between the two standards: 81/125.
All this is necessary to maintain perfect interlacing of the converter picture.
It's all pretty ancient TTL tech.
DFWB.
FERNSEH is offline
Old 17th Jan 2014, 7:57 pm   #4
Andy Green
Looks like you are doing this on the Ferguson 45T!
Andy Green is offline
Old 17th Jan 2014, 9:45 pm   #5
FERNSEH
FERNSEH's Avatar
Hi Andy,
The picture was indeed taken from the Ferguson 454T. I tried another set, a 14" GEC and that set was very tolerant of the converted video waveform. No interlace of course.
Line count apart, it is well known that 525/60 and the 625/50 systems are very similar.
The converter processed the NTSC video in same manner as it would with 625 lines.
DFWB.
FERNSEH is offline
