Old 10th Feb 2013, 2:15 pm   #1
Pete_kaye
Pete_kaye's Avatar
Default Water bottle crystal set with sound!
I was trying to construct a conical horn to improve the volume from a basic home made crystal set. I cut up a 1 litre water bottle and folded under the rough edge. The speaker is a 40 Ohm phone earpiece run from a transformer (22:1) which has the bottle sitting on it. The sound wasn't exactly deafening from a 70 foot loft aerial but audible from a few feet in a very quiet room. I can send a short WAV file to anyone who wants to hear it. Can sound files be posted on this site?
ID:	76001   Click image for larger version
Pete_kaye is offline
Old 10th Feb 2013, 3:28 pm   #2
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Re: Water bottle crystal set with sound!
Sound files (as long as they don't breach copyright obviously) can be attached if you put them in a ZIP file.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is online now
Old 10th Feb 2013, 7:31 pm   #3
Peter.N.
Excellent idea, you might get more sound from a crystal earpiece.
Peter
Peter.N. is offline
Old 10th Feb 2013, 8:31 pm   #4
Herald1360
Herald1360's Avatar
A decent horn loaded (I suppose matched would be a better term) speaker will convert about ten times as much of the input electrical power to sound as a simple cone speaker, so at best you'll only get about 10dB increase in volume. Every little helps, though
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 11th Feb 2013, 6:39 am   #5
PWH
Pink crystal earpiece, you know the ones, with a styrofoam (polystyrene) cup carefully cut out?
Even a 'normal' speaker with the output transformer attached can produce quite good sound in a quiet room in the evenings.
PWH is offline
Old 13th Feb 2013, 12:48 pm   #6
Pete_kaye
Pete_kaye's Avatar
I have tried using a crystal earpiece from a smoke detector. It needed a resistor in parallel. A very thin sound but improved by a trumpet.
Old 13th Feb 2013, 1:45 pm   #7
Radio_Dave
Radio_Dave's Avatar
Crystal earpieces can still be purchased from Maplin http://www.maplin.co.uk/crystalearpiece-3256 . There's no spec on the website but I'm sure they have (or used to have) an impedance of 1000 ohm.
Somebody once told me, back in the day, an earphone would be, simply, placed into bowl to amplify the sound. Don't know how true this?
Radio_Dave is offline
Old 13th Feb 2013, 4:54 pm   #8
Peter.N.
Yep, that's correct, a lot of people were still constructing crystal sets when I were a lad and that was one of the ways of increasing the volume.
Peter
Peter.N. is offline
Old 15th Feb 2013, 3:15 pm   #9
Pete_kaye
Pete_kaye's Avatar
My Mark 2 version has RIBENA plastic bottle cut down to form a horn about 8" high and tapered outwards..It is slightly clearer sound.
Old 21st Mar 2013, 8:08 pm   #10
DigitalNoMore
I think you'll find that crystal earpieces typically have an impedance of 20kOhms or more.
Jerry
DigitalNoMore is offline
Old 1st Apr 2013, 12:01 am   #11
Andrew2
Andrew2's Avatar
Indeed, and they have no DC path so to make the diode detector work properly you have to put a resistor in parallel.
Andy G1HBE.
Andrew2 is offline
Old 7th Apr 2013, 7:54 pm   #12
llama
llama's Avatar
...and use the bottle as the coil former?
Graham
Half my stuff is junk - trouble is, I don't know which half!
llama is offline
