Old 24th Apr 2023, 12:40 pm   #1
E93AFAN
Default Using Solid State Rectifiers To Replace Valves - Inrush Damage?
As a spring project (although it still feels like winter here in Wiltshire) I am about to make the Mullard 7 watt stereo amplifier (4 x ECL82, 1 x ECC83, 1 x EZ81), I made one back in the 60's and although not "Hi-Fi" it acquits itself pretty well.
I have all the components at hand other than a suitable mains transformer with a 6.3 volts @ 1 amp winding for the EZ81 and a separate winding @ 4 amps for the other valves, I do however have a transformer with a 4 amp winding and a 160ma 250v winding.
I considered using a silicon rectifier to replace the EZ81, but am worried that since this creates an immediate rush of unweighted HT this may push the valves beyond their safe operating voltage until the heaters are warmed up, with resultant damage. An alternate solution (again to hand) is to add a 1 amp heater transformer for the EZ81, although this is not my first preference I shall go down this route rather than using the more complex solution of "soft start" as described by other contributors here if the silicon route may cause damage.
Does anyone have a view on whether damage is likely if a solid state rectifier is used, I would welcome the wisdom of anyone who has practical experience of replacing valves with silicon in these circumstances.
Many thanks as always for your patience, kindness and support.
E93AFAN is offline
Old 24th Apr 2023, 12:52 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Using Solid State Rectifiers To Replace Valves - Inrush Damage?
The HT will rise until the valves start to draw current, but it shouldn't be enough to cause any damage. You just need to ensure that all the caps are adequately rated.
If you're really concerned about this, you could always delay the HT by 60 seconds while the heaters warm up. You could do this manually with a switch, or build a little delay circuit with a couple of transistors and a relay. This isn't very complex.
paulsherwin is online now
Old 24th Apr 2023, 1:09 pm   #3
Nuvistor
Nuvistor's Avatar
Those amplifier valves have a limit of 300v on anodes and screen grid.
Frank
Nuvistor is offline
Old 24th Apr 2023, 1:25 pm   #4
ms660
ms660's Avatar
ECL82, max. Vao & Vg2o = 550 Volts.
ECC83, max.Vao = 550 Volts.
Lawrence.
ms660 is offline
Old 24th Apr 2023, 2:58 pm   #5
Boulevardier
Even using a valve rectifier, you can't be sure that its heater won't bring the rectifier to conducting temperature before the other valves, although it should reduce the period of high HT voltage. Surely the whole circuit has to be designed to allow for a period of higher-than-normal HT voltage.
Mike
Boulevardier is offline
Old 24th Apr 2023, 3:07 pm   #6
murphyv310
murphyv310's Avatar
Hi.
The EZ81 with its indirectly heated cathode is quite slow and as the other valves start to conduct then the HT is rising so it should not rise disproportionately. The issue is with directly heated cathodes as in filamentary valves like the 5U4 etc that are virtually instant. I'd personally stick with the EZ81 which is the simplest solution.
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is online now
Old 24th Apr 2023, 3:21 pm   #7
stevehertz
stevehertz's Avatar
In the world of guitar amps, plug in SS rectifiers are available as drop in replacements for GZ34 rectifiers and I'm not aware of firstly, any mods needed, and secondly that any dangers have been advised or experienced.
https://www.hotroxuk.com/tad-solid-s...ier-rt515.html
Edit: There's a solid state drop in for the EZ81 by Groove Tubes: https://reverb.com/item/2004528-groo...-free-shipping
stevehertz is offline
Old 24th Apr 2023, 3:42 pm   #8
Boulevardier
When faced with the choice of replacing a valve rectifier with silicon rectifiers, I've always been far more concerned about the strain briefly raised HT could put on ageing reservoir and smoothing capacitors.
Once, when asked by father-in-law to do a quick running-repair to a 1940s radio with a failed octal rectifier, I removed the octal base from the old valve and used it as plug to connect a B9A valveholder for an EZ81 - using 5 bits of 2.5mm wire from stripped mains cable as connectors and "mounting pillars" for the B9A holder. A bit of a lash-up, but surprisingly rigid and completely effective, and since FiL didn't spend a whole lot of time gazing at the innards of the set, he didn't care!
Mike
Old 24th Apr 2023, 4:05 pm   #9
kalee20
I'd be inclined to try the electrolytics with the full voltage for 15 seconds or so, while watching the current.
If it doesn't rise unduly in that time, the SS rectifiers will be good to go. Future switch-ons will only get less and less of an issue as the electrolytics form themselves for the briefly higher voltage.
Presumably a 6X5 (EZ35) with 6.3V heater?
kalee20 is offline
Old 24th Apr 2023, 4:24 pm   #10
Boulevardier
Really can't remember - 50 years ago. It might well have been a UU6 - so actually Mazda octal (albeit slight overkill for Ia).
Mike
Old 24th Apr 2023, 4:54 pm   #11
Boulevardier
Mike
No, couldn't have been UU6 with its 4V heaters. So no, I can't remember now - possibly EZ35. But, whatever, obviously the valvebase would have fitted its original socket!
Mike
Old 24th Apr 2023, 7:18 pm   #12
G6Tanuki
G6Tanuki's Avatar
Assuming all other parts [electrolytics!] are healthy, I'd happily substitute a solid-state rectifier for a valve.
In times-past, the US International Rectifier Corporation produced a range of solid-state rectifier assemblies built into octal valve-bases, intended as replacements for valve rectifiers; I used these with success in the past, they generated less heat in two ways: firstly they had much lower forward-voltage-drop, and secondly by removing the filament-heating power this also reduced heat and let the mains transformer run cooler because there was less filament-power needed.
Previous thread here: https://www.vintage-radio.net/forum/...ad.php?t=65904
If you do go the semiconductor route, use modern fast-turn-off versions [UF series] rather than the obsolete and potentially-noise-generating 1N-types.
G6Tanuki is offline
Old 24th Apr 2023, 9:50 pm   #13
Bazz4CQJ
Bazz4CQJ's Avatar
An approach I've used in the past is to put some zeners and a resistor across the HT carefully chosen so that they will only conduct during that period while the valves warm up and the HT would otherwise be higher than in the normal operation. As the valves start to conduct, the HT falls to a value below the zeners' threshold.
I've also used zeners in HT circuits to get the "right voltage" to feed a voltage stabiliser tube. The temperature coefficient of the zeners is rather high to allow them to be used without the gas stabiliser.
B
Bazz4CQJ is offline
Old 25th Apr 2023, 1:48 pm   #14
PJL
Solid state rectifiers will produce a higher HT voltage which will mean higher ECL82 anode currents and possible overheating and thermal runaway. This can be overcome by a transformer with a lower HT voltage winding or some changes to the circuit resistance values. You can use Duncans PSU designer to workout what winding is needed to create the correct HT voltage.
PJL is offline
Old 25th Apr 2023, 3:54 pm   #15
stevehertz
stevehertz's Avatar
I believe that 'drop in' replacement rectifiers ie the commercially available ones with valve bases have circuitry to account for the increased efficiency. Not 100% sure on that but it's in the depths of my memory from when I was using them.
Old 25th Apr 2023, 4:58 pm   #16
E93AFAN
Thank you for your support and help, all very much appreciated.
I'll go for broke and use silicon to start with, but check the Mullard voltage data supplied with the circuit against actual voltages in operation to assess if over voltage looks like causing a problem. If it looks like a problem then it's out with the silicon and in with an EZ81.
I wish you all a happy day and thanks again.
E93AFAN is offline
Old 25th Apr 2023, 5:01 pm   #17
Silicon
Expensive communications receivers such as the American version of the Racal RA17 have used semiconductor rectifiers.
Silicon is offline
Old 26th Apr 2023, 9:14 am   #18
murphyv310
murphyv310's Avatar
Hi
Have come across these a few times and in three instances have had to replace the reservoir cap and smoother, even adding a series surge limiter the HT went way above the capacitor surge volts. A bad idea indeed, also the running HT was higher the additional surge limiter at least brought this back to the correct voltage.
Cheers,
Trevor.
Old 26th Apr 2023, 10:09 am   #19
kalee20
I'd taken it for granted that E93FAN's original post had included added resistance in series with the silicon diodes, so that the 'running' HT voltage is the same as with the EZ81, and it was only the voltage surge at switch-on that was the issue.
But looking back, I can't see any mention of this... maybe an unjustified assumption? (If so, it's simple to fix, but be sure to use adequately-rated resistors).
kalee20 is offline
Old 27th Apr 2023, 4:09 pm   #20
E93AFAN
KALEE20 - Thank you, yes I was intending to calculate the value of a chunky resistor (or two) to reduce the voltage to that expected from the EZ81, you were correct that my only concern was the application of unloaded HT at switch on.
E93AFAN is offline
