13th Apr 2021, 8:50 pm | #21 |
Re: One for old and not so old component collectors.
I used to have a little display cabinet on the wall in my old workshop with some valves, valve boxes and some other bits in it. just making use of a disused display case, and empty valve boxes!
Regards, Lloyd |
13th Apr 2021, 8:59 pm | #22 |
That looks great Lloyd; now there's an idea.
13th Apr 2021, 9:13 pm | #23 | |
13th Apr 2021, 10:10 pm | #24 |
I tried to re-stuff a resistor once... it might have worked if the ceramic didn’t crack! Gave up on that idea pretty quickly.
Regards Lloyd |
13th Apr 2021, 10:40 pm | #25 |
I have not been doing this hobby that long, but with a radio repair a 405 line TV and mainly a Solartron scope I have two bags of caps, paper, electrolytic and some form of plastic type. I think just to remind me what ever it is, just change the caps.
Adrian |
15th Apr 2021, 2:17 pm | #26 |
1960's and older parts tend to go in the bin as usually I've removed them because they're faulty or out of tolerance. Late 60's onward and I have loads of space "wasted" by keeping whole PCB's and even non working gear as donor sources for hard to get/now unobtainium parts. Leaving them on the PCB gives context to the parts and makes it much easier to locate them... that's my excuse anyway!
16th Apr 2021, 7:56 pm | #27 | ||
If they are new but out-of-spec, don't bin them! I am building up a stock for the electronics shop exhibit at EK. We need a complete shop-full of parts of all ages that have to be genuine original parts that look right but don't have to work. I need 100 boxes of new wax paper caps, all values, leakage no object. Thousands of electrolytics never to be reformed. Tens of thousands of resistors as drifty as you like. Valves with good getters but O/C heaters, trays of knobs that don't fit anything useful, boxes leaky or whiskered transistors, 1 gross of dial lamps down to air... Pulls generally aren't suitable for shop stock, but we've got the perfect exhibit for those... the Hobbyist's Shed! I already have a bazillion used components to fill the plastic drawers in that, and next week the shed is arriving to put them in. That's as leaky as the duff capacitors, but it's going inside the warehouse so it doesn't matter. Quote:
16th Apr 2021, 8:13 pm | #28 |
I like to keep some of the more interesting capacitors that I have swapped out. I tend not to hold on to old Hunts waxies as they are very commonplace and messy to keep. However some of the early ones with interesting graphics or a paper label with the makers name and component parameters are worth keeping as a historical reference. The early American "snip-outs" in particular can be rather colourful.
Neil
preserving the recent past, for the distant future. |
