3rd Mar 2020, 6:16 pm | #41 |
Re: Henley Solon 25W Soldering Iron Revival
Yes, the old Antex irons did used to get solid, but I never had a problem removing old bits. I've got a couple, one of which I've had since the 60s and it's on its third element and strangely probably not that many more bits.
You're going to laugh now, seeing as it's to hand at the moment, I'm just using that Solon with the remains of that bit to do a temporary soldering of pickup wires onto a record deck I'm testing. That's the first time it's seen the mains for many years and the penetrating fluid did smoke a bit when it first warmed up. |
7th Mar 2020, 1:51 am | #42 |
I've fitted a normal soldering bit to the special print fixing Ademco / Henley Solon soldering iron today. I sorted out a selection of various bits and in the end went for one of the types that I have as spares for my old RS temperature controlled iron that I still use regularly. I shortened it, but perhaps should have shortened it a little more, but it'll do - I had to drill a hole in it for the cotter pin. I had thought of using one of the Weller type bits I've got, but the shaft would have needed reducing in diameter very slightly. It works very well and I shall make sure the bit doesn't get stuck over time so that I can always go back to the 'special' bit if I need to. The bit I've fitted is copper, but with a plating on it, so hopefully won't tend to have the reaction between the copper and alloy - or at least not for a while.
7th Mar 2020, 10:39 am | #43 |
Looks very usable and I guess you managed to extract the old pin without too much trouble. I would have thought that it's quite possible that the iron plating will interact with the aluminium tip holder as it's what dissimilar metals like to do, especially in the presence of a little humidity and plenty of heat.
Alan |
7th Mar 2020, 1:07 pm | #44 |
A fascinating thread indeed! Re: post #39, my Solon 25 watt iron has exactly that, an o/c element. I'm under the impression that these were long obsolete. Is this correct? I'd love to get it going again. I've amassed quite a few irons over the years; from 15 watts up to 100 watts with various voltages, 50, 110, 230 as well as 240, and also a gas powered one! I also had a Remploy. A firm that gave employment to disabled folk. I remember the little light in it, but it didn't give much illumination. One iron I had was a cheapo 'Lyvia' iron which had a handle that unscrewed and fitted over the barrel of the iron. It didn't last long! Cheers. Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..." Last edited by Tractorfan; 7th Mar 2020 at 1:12 pm. Reason: Rearranging my worms. |
7th Mar 2020, 2:54 pm | #45 | |
If you're feeling brave you could try removing the faulty element to see if it's possible to effect a repair. Not much to lose in the end. Most of the information needed to try this is contained within this thread's early posts. Referring to the attached low resolution photo the arrow indicates where the element slides into its steel sleeve. The insulating mica can be seen protruding fom the sleeve. If this is withdrawn the element will come out with it. There are several pieces of delicate mica and you'd need to take very careful note of how they are arranged in order to stand a chance of successful reassembly. Not at all easy. Alan |
