15th Sep 2021, 10:21 am | #1 |
Bush vintage radio DAC90A.
Recently bought the above radio, and although not working it seems in quite good order.
I suspect the valves are the problem. Some are black and obviously not working. Some seems relatively new. The print on some are partly or wholly unreadable. Can anyone tell me all five valves full details and the best place to purchase them Thanks Cammy |
15th Sep 2021, 10:27 am | #2 |
Re: Bush vintage radio dac90a
Hi Cammy and welcome to the forum.
The DAC90A is well known on this forum. First you cannot tell the state of a valve by it's appearance. The black you describe is the getter and unless its milky white tells you nothing about the valve. Do you have a Multimeter, do you know how to work safely on live equipment? The service info (including valve types) is available here: https://www.service-data.com/product.php/603/951/m10603 You could do worse than start here: https://www.vintage-radio.com/repair...ion/index.html Cheers Mike T
15th Sep 2021, 12:12 pm | #3 |
Valves are least likely to be your problem....it's a common beginners belief that 'it's the valve'!! Most of this is from the old days of radio repairs where replacing a valve got the set going.....for a while until it failed again simply because the proper cause of the fault hadn't been traced.
If the radio has not been serviced, it will need all the capacitors replaced for a start (these will work out a lot cheaper than a full set of valves). That may well be all that is required. Do not be tempted to plug it in at this stage. If you are an absolute beginner please take note that this set does not use an isolating transformer and the chassis is connected directly to the mains. Extra care has to be exercised when working on these sets. For an idea of what is involved when working on these sets, please search the forums for DAC90A. There must be hundreds of threads about these...one of the most popular sets ever.
15th Sep 2021, 6:36 pm | #4 | |
15th Sep 2021, 7:19 pm | #5 | |
Please please please take the precautions as previously stated - and enjoy! Keep us all posted.
I was so upset that I cried all the way to the chip shop. |
15th Sep 2021, 11:00 pm | #6 |
Re: Bush vintage radio DAC90A.
Also, do not attempt to pull / lever the knobs off the set. Slacken the screw in knob through the holes underneath the set, and for side knob it is inside the back of set.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
15th Sep 2021, 11:32 pm | #7 | |
Paul Last edited by Paul_RK; 15th Sep 2021 at 11:46 pm. |
16th Sep 2021, 12:51 am | #8 | |
I'm very shocked and surprised at Sideband advising replacing ALL the capacitors - I would have thought he'd be the last person to suggest such a thing to an obvious total novice. We've already got a thread running that I spotted earlier where it sounds like the person has replaced everything including probably the silver mica flat types and has now got squealing and howling and a non-working radio! The only other thing that I don't agree with is regarding removing and throwing away the springs on the valve holders. I say just carefully lever them up out of the way of the pip and rest them on the metalwork of the skirt when removing the valve, then on replacing the valve just carefully let them back down into the slot. People need to learn to be proper radio engineers and not just remove and dispose of original parts just because they don't know how to deal with them properly - if the radio is ever sent through the post, then you'll wish those springs were in place when you find all the valves floating around and smashed inside the cabinet...OK, so you're going to say that the whole radio is unlikely to survive the postal system if it gets chucked around enough to knock all the valves out of their sockets, so why worry about the springs being missing and you could be right |
16th Sep 2021, 1:29 am | #9 |
Welcome to the Forum. A lifetimes experience in 8 posts already cammy! Sideband clearly outlined the "It's the valve isn't it? urban myth." The idea of automatically replacing all the caps as a matter of course is not a myth. It seems to have originated in American Hi Fi circles but nobody really knows as you can see from threads on that subject. This approach was unknown until relatively recently. It probably spread via the internet and is only really useful if the restorer is either extremely experienced generally or within one speciality [I'm not] or seeking to replace everything, which will be an arduous task and very likely to lead to greater confusion, as said. I'm sure Sideband is fully qualified to take the risk but it's not a good idea otherwise. Guess work is not the way forward overall.
I wonder how you came to believe that valve problems can be diagnosed externally? Maybe you replaced one or two darkened ones and the set worked so you thought that was all there is to itv Dave W Last edited by dave walsh; 16th Sep 2021 at 1:35 am. |
16th Sep 2021, 1:58 am | #10 |
Saying replace ALL the capacitors is a very dangerous thing to say to a novice. I can only think that Sideband wasn't thinking when he said that - I know I've probably said things without thinking and caused possible confusion.
ALL the capacitors includes the silver mica types that'll destroy the alignment if they're disturbed for replacement and will need specialised test equipment (which the OP won't have or even be able to afford) to put things right. It also includes the main smoothing can which virtually never fail on this model of radio. What he should have said was ALL the round, wax paper types that are mainly on the tag board. They will all be faulty as regards having leakage, but it's only really the one feeding the output valve control grid at the end of the board that's critical and should ALWAYS be replaced. There's a screen grid decoupler on that tag board and just for the hell of it on mine I removed all the solder from one end connection and carefully unwound the wire from the tag and lifted the end of the capacitor away. It measured leaky and I'd previously checked the screen grid voltage while it was still in circuit and it was in the ball-park of what it should be. I tacked a new replacement capacitor in place and it made about half a volt difference to the screen voltage and no noticeable difference to performance, so I unsoldered it and carefully wound the wire of the original capacitor back on its tag and re-soldered the connection. What I would say is that all those half dozen or so round wax paper capacitors on that tag board WILL be leaky to some degree and it could be that if the radio has spent many years in a damp shed or similar place, then the absorption of moisture and leakage of all of them could be enough to compromise the performance of the radio, so it wouldn't be too bad a thing to replace them as well as that critical one at the end, but it's easy to make mistakes when replacing a group of components in one go. What you need to do, seeing as it sounds like the radio has already been powered up, is to disconnect that wax cap by the on/off switch and on top of the chassis (if it's still there) and then replace just the grid coupling capacitor. If the set still doesn't work, then it's time to do proper fault finding by taking voltage readings as a first start. Be very careful around high voltages and remember that one side of the mains goes straight to the chassis metalwork on these particular sets! |
16th Sep 2021, 2:04 am | #11 |
Hey Dave, are you trying to get your post count up? Double post!
I agree with what you say! |
16th Sep 2021, 10:46 am | #12 |
Blimey, quick to condemn, don't panic Mr Mainwaring...
I'm sure Sideband meant the usual capacitors. Lawrence. |
16th Sep 2021, 11:15 am | #13 |
What Sideband meant and what the OP may have understood him to have meant are two different things.
A bit of clarification (not condemnation) has done no harm. Previous threads suggest that some sets never work again after changing ALL the capacitors.
16th Sep 2021, 11:30 am | #14 |
16th Sep 2021, 11:38 am | #15 |
I expect so. What I regard as proper fault finding seems to be going out of the window. You just replace all the capacitors and out of spec resistors, give the pots and switch contacts a squirt of Servisol 10 and magically it all works.
Who needs a test meter or other test gear? Let's wait for a response from the OP.
16th Sep 2021, 3:47 pm | #16 |
Yes I hope cammy comes back on this. Unfortunately some posters are never heard from again. I usually spot when I've doubled up Techman but it was late I've too much to say as it is but unfortunately less is usually more so I'm afraid the many posts that I've done already signifies very little
Dave |
16th Sep 2021, 4:43 pm | #17 |
I now need to buy loads of valves and replace them in every set for good measure, it will only cost hundreds to do so but everyone knows that all valves found in every set are defective, it's a light bulb after all.
The above statement is random crap I made up, we all know how reliable valves can be, apart from the UL41 but the rest are fine. The point I'm making is, why do so many people think a valve works like a bulb? The mind boggles.
Rick, the annoying object roaming the forum. |
16th Sep 2021, 5:28 pm | #18 |
No matter what experienced advice is given, guys usually go their own way with the obvious disasters. I have always been a 'get it working regardless of how badly' before mass changing components.
You cannot become a radio repair guy with one recapping of a DAC90. Never has so much been written about a 5 valve AC/DC superhet. Just take care and new guys on the block, please change one component at a time checking the results as you go. You need a service manual and a test meter and know how to use it. A very cheap meter is all that is required for radio repairs. Aim to get a first squeak out of it and the rest should be easy. J. |
16th Sep 2021, 6:14 pm | #19 |
There is/was a basic capacitor kit available on eBay and elsewhere for the DAC90A with instructions, I can't think of a better start for restoring one. Only the capacitors likely to fail are included, not all as the RF mica jobs are super reliable.
16th Sep 2021, 6:21 pm | #20 |
Maybe my approach is wrong but it goes something like this, test valves first, test the speaker TX primary, change any waxy things for good measure, reform the electrolytic can, check the output cathode resistor.
If the set works after all that work, leave it alone, alignment is only performed as a last resort, this had to be done on the octal version DAC90, it was seriously misaligned but now works perfectly.
