7th Sep 2021, 5:16 pm | #1 |
Garrard 86SB Mark 2
I'v just bought a Garrard 86SB Mk 2 deck knowing the auto mechanism wasn't working but assumed that the motor etc would work.
Wonder if anyone can suggest any obvious things to check before I think of having it repaired? |
7th Sep 2021, 5:45 pm | #2 |
Re: Garrard 86SB Mark 2
Welcome. The issue you have here is very common. Do you not feel confident to remove the platter and check out the idler drive and cam/trip pawl assembly which is probably the cause of the problem? Have you yet checked the motor runs and the cartridge is OK?
Edward. |
13th Sep 2021, 4:53 pm | #3 |
Thanks Edward
First time I'v tinkered with record decks so was a bit cautious. I obtained the manual which gave me a lot more confidence - Found it needed a new belt but idler drive was working ok. Bazer |
