Old 16th Sep 2021, 3:32 pm   #1
pentoad
Default What is the resistor wattage of these examples
The brown one is 19mm body length, I think is 1 watt maybe 2watt
The white ones are 30mm body length maybe 2watt
ID:	241436   Click image for larger version
pentoad is offline
Old 16th Sep 2021, 3:44 pm   #2
Default Re: What is the resistor wattage of these examples
1st photo 1 Watt, 2nd photo 2 Watts a piece I would say.
Old 16th Sep 2021, 4:44 pm   #3
dazzlevision
The first one could be an Allen Bradley hot moulded carbon (composition) or a Radiospares 2 Watt carbon composition type.
The second is an Erie ceramic cased carbon composition type - around 2Watts.
dazzlevision is offline
Old 16th Sep 2021, 5:08 pm   #4
Hartley118
Hartley118's Avatar
Resistor wattage rating is a rather interesting topic. How come that today’s resistors can be so tiny compared with those of 60 years ago?
What design factors determine the wattage rating? Thinking aloud…..
Larger surface area clearly increases rate of thermal dissipation by convection, so it makes sense that higher power devices are larger.
Thermal resistance between resistor element and external surface will vary. The old ‘dogbone’ resistors only had a layer of paint, but the later Erie tubulars had an outer ceramic shell which presumably increased thermal resistance. What of today’s carbon film and metal film resistors? I guess we’re back to just a layer of paint between the resistive element and free air.
So are modern film resistors more tolerant of higher temperature operation than their vintage equivalents? Their smaller size suggests that they are.
Martin
BVWS Member
Hartley118 is offline
Old 16th Sep 2021, 5:27 pm   #5
whiskas
whiskas's Avatar
I agree 1W for the first resistor on the left, and 2W for the Erie on the right.
...where on earth did that spring/screw go??
whiskas is offline
Old 16th Sep 2021, 7:46 pm   #6
The Philpott
The Philpott's Avatar
Interesting that my Erie Hi-stab (30mm long) 1% resistors are labelled on the box as 1w- presumably de-rated to ensure they maintain their 1% performance.
Dave
The Philpott is offline
Old 16th Sep 2021, 8:54 pm   #7
Lucien Nunes
Yes, this is the crux of it. Compared to composition resistors, they are able to withstand higher temperatures without drift or damage, and have lower temperature coefficients of resistance, therefore can be run hotter with no detrimental impact on performance. As far as power rating is concerned, the only way in which composition outperforms film is its ability to absorb high peak impulse power, as the dissipation occurs throughout the slug instead of within the very low mass of the spiral element.
Erie did quote two different power ratings for different ambient temperatures (IIRC half the rating at 70 deg.C. compared to 30) and the I seem to recall the default rating for the cracked carbon types being at the higher temperature. I have the datasheet somewhere.
Lucien Nunes is offline
Old 16th Sep 2021, 11:35 pm   #8
joebog1
I remember even in the 60's that Philips rated their carbon films two ways.
1 watt @ 100 C and
1/2 watt @ 70 degrees.
Moulded carbon drift without heat, horrible noise makers.
IRC made VERY small resistors in the 60's too, renowned for the end caps breaking off. They were only about 6mm long and about 1 1/2 mm long and rated at 1/2 watt. I also remember many imprints in my finger tips from the temperature they ran at. They were made on ceramic formers.
As to the origional question, 1 watt and 2 watts as most of us have mentioned.
Joe
joebog1 is offline
Old 19th Sep 2021, 7:09 pm   #9
pentoad
I have just bought some quarter watt 5% Allen Bradley NOS carbon comp, two thirds of them were way out, between 11% and 20% - dissapointing
They are tiny in size compared to the original ones also.
pentoad is offline
Old 19th Sep 2021, 7:27 pm   #10
GrimJosef
I understood that the main difference with modern resistors was that they are rated to withstand a certain power dissipation as long as you can find a way of keeping their surface temperature within the specified limit. Back in the day the manufacturers took that responsibility for you. They rated their components to survive at the specified power as long as they were in something close to 'free air' which wasn't unduly hot. These days keeping the temperature down is your problem, not theirs.
GJ
http://www.ampregen.com
GrimJosef is offline
