#241 | ||
Do you mean PSU cap C2? That has 381V across it, and is paper-in-oil. There aren't any 8uf caps in the amp itself. HT on the amp is 178V after the 10k load, and just over 200V at the PSU.
#242 |
I see you have disconnected the earth and 1K resistor from the secondary which I missed from my instructions.
For push-pull transformers the correct measurement for turns ratio is primary 'anode to anode' to secondary. Attached is the A2134 datasheet which shows how the optimal load impedance varies from 3-7.5K dependant on operating conditions (particularly the HT) none of which match our example with UL taps and low anode current. With 250V HT I would aim for about 6K. The required turns ratio for various speaker impedances is then: 4 ohms = square root(6000/4) = 39 8 ohms = square root(6000/8) = 27 16 ohms = square root(6000/16) = 19 Remove valves and disconnect HT. Confirm anodes are primary 3 and 4. I am a little concerned about unwanted capacitive coupling in the transformer so put a 1K resistor load on the first secondary (AB). Then put your 6.3V on 3 and 4 of the primary and measure the AC voltage on the primary 34 then measure the first secondary (AB). Move the 1K resistor load to the other secondary (CD) then measure the AC voltage on the primary 34 (again) and measure the AC voltage on this. |
#243 |
I was referencing the updated schematic by PJL in post #141. Should we be using a different circuit schematic to follow along?
#244 | |
I managed to break my other meter, i.e. the one that gave correct LT readings, so had to make do with the one with the 500k resistor across AC. With LT strapped across 3 and 4, my multimeter measures 5.8V. Slightly lower than 6.3V, but as PJL said this is likely because of that 500k resistor. I measured AC voltage across secondary terminals AB, but got 0V, with and without a 1K resistor across AB. Same with CD. |
#245 | |
https://harnessontheleftnape.blogspot.com/2025/11/mystery-amp-schematic.html |
#246 |
The secondary connections depend on the choice of left/right transformer but you can confirm by checking continuity of A to B and C to D. It's also possible your meter may not be able to measure low AC voltages.
#247 |
There is continuity between A and B, and there is continuity between C and D.
With LT across primary terminals 1-2, the meter measures 0.4V AC across secondary terminals A-B. Again, less than the 0.7V AC measured with the other meter. I'll have a look at getting a better meter. |
#248 |
My new valves have arrived. The guy couldn't find the valves I'd ordered, so I ordered a different pair, described as giving "similar emissions". I've just tested the amp with them plugged in. Their cathode voltages are 11.78V and 12.5V DC. Not overly well matched.
This time both speakers made a hum that got louder as the valves warmed up - I didn't notice any sound last time. HT fell from 232V with no load to 211V with the amp plugged in. I've ordered a Fluke 25 which should arrive in a few days. |
#249 | ||
I've been trying to follow this far, a few observations. 200 to 250v HT is tad low to get the best out this amp. For a PP amp you want 300v at least. I'd get the amp mostly going & not worry too much about getting everything perfect. One you have an OP you can then tweak. Still, we all go about things differently.
It's a shame you don't have a scope. There are free PC ones which are good & with a cheap soundcard & a few resistors it would will enable to test amps better going forward. Well chuffed to see you get this far, Andy.
#250 |
3.8%, that match is very close.
You put the links and connections to the speaker terminals back exactly as they were originally? You are running without the lamp limiter and all valves in? Once you have the new meter you need to complete the output transformer test so we can work out how to wire it for your 4 ohm speakers. Be careful measuring current with your Fluke as the fuses are very expensive. |
#251 |
Thanks Andy!
Not exactly, I've used alligator leads to save having to re-solder (see pic) |
#252 | |
Posts crossed with PJL -
Andy.
#253 |
#254 |
I've re-fitted the valves and the hum is much quieter now.
#255 |
I also use those patch leads and they are not great so solder it all back together.
Switch on and adjust the HT slowly up to 250V. If the hum gets unbearable switch off as we will need dummy loads (10W power resistors) of say 4-16 ohms. Measure all 4 cathode voltages again. Measure anode voltages CV4006 pin 6, ECC83 pin 6 and pin 1. Only use the FNIRSI 5012H with the 10X probe as >80V will damage it but it should work well for use with the amp. |
#256 |
Cathode voltages V3 - V6:
15.2, 14.2, 14.4, 14.6V DC V1 anode: 38V V2 anode 1: 150V V2 anode 2: 151V V7 anode 1: 84V V7 anode 2: 88V V8 anode: 21V Hum got reasonably loud when valves warmed up, but quickly quietened down. Last edited by Kokotoni Will; 1st Dec 2025 at 7:10 pm. |
#257 |
And the anode voltages?
#258 |
#259 |
Looks like voltages on the right channel are about 50% those on the left. I've taken voltages across the filter caps, and it's the same story:
C10: 92V C11: 192V C12/13: 250V C23: 106V C24: 50V C25/26: 250V I've noticed that, as well as humming quietly, the right channel picks up interference from mobile phones, and pops when the unit is powered off, whereas the left channel just hisses quietly. |
#260 |
V8 anode voltage is too low and that sets the bias conditions for V7 and that affects all the other voltages.
Swap the CV4006's over and see if the anode voltages change. |
