Reply
Old 29th Apr 2025, 8:39 am   #1
samjmann
samjmann's Avatar
Default Technics SL-PS700 CD Player servo fault.
This player is now 30 years old. I still think of CD's as newish!
It would focus, but the disc speed was slow and of course there was no TOC read either.
This was designed as a so called 2nd generation player. Linear sled motor and 'Digital' servo also. Digital was also shown on the VFD display.
The servo and RF pre-amp are all on a small pcb on the underside of the laser/loader block. Access was near impossible for testing. After removing the whole block I gently warmed the small servo board and quickly reassembled. The player then read the TOC and played for 2mins, then failed to read again. The board had 10+ sub miniature through the hole electrolytics.
Separating the flat foil of the laser head from the connector was near impossible. If this tears, the unit is instant scrap!
Because of this I decided to re-cap the servo board in one go.
I hate this approach, but the propensity of damage to the laser ribbon escalated with each removal.
RS stocked direct replacements of all the small electrolytics.
The photo shows the finished board.There were 3 non-polarised electrolytics that I didn't swop. They did test perfect however.
On reassembly it worked first go. Near instant TOC read. Track selection was extremely fast. I've one CD that's got a 79min playing time. (Longer than Red Book spec?). Again tracking and playability was 100%.
As mentioned earlier, a block change of parts isn't without risks and can easily lead you down a rabbit hole. However there are times when you don't have many options!!
SJM.
It's never been right since we've had it...
samjmann is offline   Reply With Quote
Old 29th Apr 2025, 8:41 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Technics SL-PS700 CD Player servo fault.
Fantastic result, completely agree with your logic!
Nickthedentist is online now   Reply With Quote
Old 27th Jul 2025, 8:37 am   #3
Station X
Station X's Avatar
One post moved to a new thread here:-
https://www.vintage-radio.net/forum/showthread.php?t=221214
Graham. Forum Moderator
Station X is online now   Reply With Quote
Reply
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
