Old 28th Aug 2023, 10:29 am   #1
line sync
Default Degrading TV rubber masks.
I think many of us vintage television collectors have come across a crt mask which is badly cracked , melted , drooped or turned into a sticky mess.
This is becoming more of a problem as time goes by and the rubber slowly degrades so i,m asking if anyone knows of maybe a chemical / solution that could be applied to the rubber to make it last a bit longer.
The youngest of these masks are almost 70 years old and would never have been designed to last this long.
I have been doing some research into rubber and apparently all rubber will go this way eventually so we might have to get creative making masks ourselves out of wood or even moulding them.
line sync is offline
Old 28th Aug 2023, 3:34 pm   #2
stevehertz
stevehertz's Avatar
Default Re: Degrading TV rubber masks.
I had one of the Pye 817 5" vision only sets that was restored at great cost by Philips for use at the Great Optical Illusion show at the Science Museum in London in the late 70s. They actually had three at the show for backup purposes. Gordon Bussey the then 'historic expert' for Philips oversaw the restoration of the sets, and the masks were carved from expanded polystyrene and then smoothed over with something like plaster of paris to get a good finish. Obviously this is nothing like the 'proper' rubber mask, but it looks good enough and it should last. Otherwise make one out of wood and use it to make a mould and then mould one out of silicon. A big job..
stevehertz is offline
Old 28th Aug 2023, 3:44 pm   #3
G6Tanuki
G6Tanuki's Avatar
To me this looks like a good target for additive manufacture AKA 3D printing.
It would depend on the availability of an un-sagged rubber surround for scanning, and the identification of a suitably elastic material to render the new one.
"Anything Can Happen In The Next Half Hour!" -- Stingray (1965).
G6Tanuki is offline
Old 28th Aug 2023, 4:08 pm   #4
Panrock
Panrock's Avatar
I recall one set I came across with the original mask stuck on to the tube, warped and 'melted'. I think this was a Murphy V136C. I basically painted on a new rubber mask over a period of several months, layer-by-layer, allowing setting between layers, with black roofing mastic.
This was a slow process, but there was plenty of time to make small corrections to build up the right shape.
Steve
https://www.radiocraft.co.uk
Panrock is offline
Old 30th Aug 2023, 5:17 am   #5
German Dalek
German Dalek's Avatar
Hi folks!
A better way, as far the mask is not melted away, is to use products from Voss Chemie.
https://www.vosschemie.de/en/
If melted, you have to rebuild one made of "play dough" or something like that. Then you can make a copy to produce a new rubber mask.
They are selling different kind of chemical products, even in small (household-typical) sizes.
For example, they are offering "molding compounds", if translated right.
You can use a dying mask to make a copy of it and with another product from this company you fill that material into the negative.
Therefor they are offering products made of different kind of rubber.
Their material is able to deal with undercuts!
Some of there products are available at:
https://www.yachtshop24.com/Vosschemie-Sicovoss-RF-Silikon-Abformmasse
The best is to contact them, and they give you an advice.
In the USA we had reproductions for the Motorola VT 71/73 models with the 7" CRT.
I bought 2 of them and they are good.
Regards,
German Dalek
And now for something completly different:
MARC BOLAN, he was/is the real king of Pop Music!
German Dalek is offline
Old 2nd Sep 2023, 7:08 am   #6
line sync
Thank you to all for your comments.
Polystyrene and similar packing materials is a good idea steve , i am thinking that i could carve up this using a hot wire .
I do have a 9" mask made from aluminium and this would be ideal for the rubber moulding process but alot of masks wrap around the bowel of the crt and this would be a difficult mould to make.
Robin
Old 4th Sep 2023, 2:04 pm   #7
German Dalek
Robin
No, not with the material from Voss Chemie.
As I wrote above, they have elastic rubbers, which will deal with undercuts!
Regards,
German Dalek
Old 5th Sep 2023, 10:41 pm   #8
matspar
matspar's Avatar
Here's an approach I used on a Philips 383A last year.
First of all I cut a piece of thin 2mm white acrylic to fit over the front face of the mask, which was glued into place. Next I masked up the faceplate of a scrap CRM92 and mounted it vertically with some timber supports. This would maintain the correct profiles of the mask.
The sagged and damaged areas were then built up with decorators caulk, which maintains a degree of flexibility when cured and is overpaintable. Several applications and careful smoothing out needed. It was then sprayed grey with one of the the popular 'chalk' paints which provided an identical finish to how it was originally. Lots of patience required of course!
ID:	284574   Click image for larger version
ID:	284575   Click image for larger version
ID:	284576   Click image for larger version
ID:	284577   Click image for larger version
matspar is offline
Old 6th Sep 2023, 4:40 pm   #9
line sync
Nicely done matt.
I didn't think of using decorators chalk and nice to know that it sticks to the rubber ok.
Robin
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
