10th Feb 2019, 12:06 am | #1 |
TF2700: variant ident. by serial number?
Marconi TF2700. There seems to be at least two variants of this instrument: the early model (1962), which uses GET102 and OC200 transistors; the later one (1974) which uses ACY17 and BCY72 transistors. (There may be other variants, but I could not find any references to such.)
My question is this. If the serial number (of format nnnnnn/mmm) of a particular TF2700 is known, it is then possible to identify which build type it is of the two? All replies will be much appreciated. Al. |
