29th Jan 2019, 7:37 pm | #1 |
Grinding TK23 loose wire [Grundig]
Can any one please help I have purchased this TK23 and got it all working playing but no record I found this loose cable can any one tell me where it goes as I have no clue I have taken pictures
29th Jan 2019, 7:43 pm | #2 |
Re: Grinding TK23 loose wire
Sorry here are the pictures thank you if any one can help please
29th Jan 2019, 9:09 pm | #3 |
It’s difficult to make out which cable you are referring to. However there is a green/yellow with red sleeves in your pictures that looks to me like a modern addition. If it is a single core could it be a grounding wire that had been installed to strap two assemblies to the same (earth) potential, that has now come adrift?
Have you got a TK23 circuit diagram to refer to? Bill |
29th Jan 2019, 9:25 pm | #4 |
No sorry I have not got a diagramm the cable is screened cable clear colour with a red tip it comes from a set of contacts as I said all works but record and I was wondering whether it was this cable that was the problem thank you anyway
29th Jan 2019, 10:35 pm | #5 |
Re: Grinding TK23 loose wire [Grundig]
It's possible that it connects to switch "at1" as designated in the makers schematic, I say this because there should be a connection via a screened lead between switch "st1" and one of the contacts of "at1" according to the said schematic.
In your 3rd photo, switch "st1" is on the "st" switch assembly that's shown in the upper half of that photo and switch "at1" is on the switch assembly shown on the right hand side of that photo, "at1" has two contacts and the said switch assembly consists of switches "at1" and the "tt" switches, the other contact for switch "at1" is connected via a screened lead to switch contact 14 on the record/playback switch which is located on the main printed circuit board...….So far as I can make out. The makers manual....layout/schematics etc is available from the vintageshifi web site. Lawrence. Last edited by ms660; 29th Jan 2019 at 10:51 pm. Reason: Clarification |
30th Jan 2019, 6:56 pm | #6 |
Than you for help
