4th May 2023, 2:42 pm | #1 |
ECL86 exposed...!
Hello,
Just a little one for the interesting pile… In the past there have been discussions, whether the ECL86 was a beam tetrode or a pentode… Sadly, a Mullard ECL86 valve got damaged in transit, however, looking on the bright side, it enabled me to remove the anode to expose the innards to get sight of the beam plates confirming it’s a beam tetrode. I must marvel at the internal construction of this valve. Pictures attached. The poor ‘ole ECL86 didn’t die in vain! Terry |
4th May 2023, 4:53 pm | #2 |
Re: ECL86 exposed...!
Thanks! I'd always believed the ECL86 was a beam tetrode, irrespective of how the Mullard data sheet described it.
4th May 2023, 5:11 pm | #3 |
Pentode and tetrode in here:
http://www.r-type.org/exhib/abv0085.htm Are the plates connected to anything? Lawrence. Last edited by ms660; 4th May 2023 at 5:39 pm. Reason: extra info |
4th May 2023, 5:12 pm | #4 |
Sad, but look at it this way, it's never going to have grid-current problems!
David. |
4th May 2023, 5:17 pm | #5 |
It doesn't appear to be a true beam tetrode though, the control grid & screen grid aren't aligned with each other...
Mark |
4th May 2023, 6:13 pm | #6 |
It did cross my mind they used beam plates instead of grid wires to enable the manufacture of the valve, given the physical size and target anode dissipation.
The plates along with the internal screening connect the the cathode. Terry |
4th May 2023, 7:56 pm | #7 |
There's a certain odour to the insides of a valve - exactly what is it?
13th May 2023, 6:49 pm | #8 |
It's a sharp distinctive odour that you always remember afterwards!
For an output valve to be a true beam tetrode the control and screen grids need to be aligned to funnel the electron streams into the beams as per the original RCA diagram, so I would class the ECL86 to have pentode characteristics! The ECL82 is described in Mullard's data as a "triode–pentode" but a "beam tetrode" in Mazda's data and most diagrams draw the ECL82 as a triode–beam tetrode. The PCL85/PCL805 uses metal plates for G3 with otherwise a pentode construction as well. However, the smaller ECL83/PCL83 is a true pentode with a wound suppressor grid, as is the EL84! Chris Williams
13th May 2023, 7:21 pm | #9 |
Isn't the distinctive pong "Essence of Getter Oxide".
Bottle it and sell it. Oh- but that would be second time around. |
13th May 2023, 7:29 pm | #10 |
The smell would be the near instant reaction of the barium getter to a barium oxide compound. You can get a similar smell filing pure aluminium as this oxidises quite fast.
It is interesting that if you (accidentally) break a valve and put a drop of water on the getter ring, it fizzes as if turned to lemonade. Obviously a reaction of the remaining barium metal still present in the getter ring. Obvious precautions needed as I have no idea of what these compounds would do to you !! Christopher Capener
