1st Apr 2023, 2:59 pm | #1 |
Location: Carrickfergus, County Antrim, Northern Ireland, UK.
Philips fm1100 with extended board over control board
I have an fm1100 with an extra board in an extended cover over the control board. This board was used to enable a cross band repeater to be made up by using a similar radio but on UHF. Does anyone have any information on these spcial boards? I was thinking if I could use this board to interface a microphone as I don't have the standard mic. I know that these radios are rare and this system was used before the repeater stack system was introduced so any information would be appreciated.
Dave |
1st Apr 2023, 5:11 pm | #2 |
Re: Philips fm1100 with extended board over control board
Is there an AT or similar number on your board Dave?
Martin G4NCE |
3rd Apr 2023, 2:13 pm | #3 |
Hello Martin, there is no AT number on my board just a couple of 3513 numbers. 3513 560 00261 and 3513 968 00151.
I tried to attach a photo of the board on this reply but I could not. Could you PM me your email address please so that I might send the photo in a private email. Thanks, Dave GI8LCJ Last edited by Station X; 3rd Apr 2023 at 5:42 pm. Reason: Email address removed to comply with forum rules. |
5th Apr 2023, 9:41 am | #4 |
After a bit of searching I have found the FM1100 mobile repeater info I have here Dave. Looks like it’s the stack version though. 3513 568 0005, 3513 568 0007 and 3513 568 0029, which are mods to the 3513 560 00181 PCB. Also a sheet detailing the mod to add CTCSS to the stack, 3513 568 3086, which references the 3513 568 30301 in the text.
You are welcome to a copy if it helps. Cheers, Martin G4NCE |
5th Apr 2023, 10:24 am | #5 |
Ok Martin as none of those numbers you have match the ones on my board don't bother using up your time. As I said these units were a very early method of creating a repeater. I will have a poke arround myself with what I have. As I have a 2955A test set I should be able to see the tx level and possibly use a generic microphone. It will keep me out of mischief for a while lol.
Thanks Dave GI8LCJ |
