28th Mar 2023, 4:26 pm | #1 |
Medical stimulator
This is another of the items from my friend's late husband's collection. It isn't "household" but this seems the nearest category. I'm not posting it in the Offered section because I suspect no-one would want it, but perhaps we can find out a bit about it.
This web page http://www.simoncornwell.com/urbex/h...e130702/96.htm describes some related equipment though not this particular model. The single valve is a PCL83. I don't know what the brown cylindrical component between the valve and the transformer is. Whatever it may be, it is supported by a pair of thin blades that seem to be slipped in between the transformer laminations. Between that component and the front panel is a glass object, a bit like a miniature valve but thinner, with a few wires coming from the bottom end and going through a grommet to the circuitry under the chassis. Any thoughts about these components? |
28th Mar 2023, 4:55 pm | #2 |
Re: Medical stimulator
The glass object looks like a DM70 'magic eye' indicator. They were often used in tape recorders to indicate the volume level when recording. A green glow akin to an exclamation mark (!) extends as the level rises until the column touches the dot. Hope this helps. A fascinating piece of kit! Cheers, Pete.
28th Mar 2023, 4:58 pm | #3 |
I assume this to be a forerunner of the TENS machine, which is designed to stimulate the muscles by means of an electric current. TENS machines normally have pads that attach to the skin to deliver this current. Does this have anything equivalent?
I should add that such electro-medical devices are an area of collecting that I include in my interest.
28th Mar 2023, 5:13 pm | #4 | |
I agree that the glass device is likely a DM70; the slot for its display is clearly visible in the front panel.
Attached to the brown cylinder is what appears to be an arm extending from the side of the transformer. Evidently more than a mechanical anchorage, it passes through a slot in the wraparound frame and is perhaps embedded into the lamination stack, being itself perhaps a piece of lam. It might couple a coil to the transformer or something - would need more pics / schematics to clarify. Quote:
28th Mar 2023, 5:59 pm | #5 |
Yes it looks like the antique version of EMS Electro-Muscle Stimulators/TENS. It can produce different pulse widths, waveforms and frequencies of microcurrents. I read a lot of research papers about them and I own several of the modern and very expensive versions of such professional medical devices made by manufacturers like Complex, Globus and Neurotrac. I used them to prevent muscle atrophy under a physiotherapist's guidance before and after major shoulder surgery and also back pain! I have been lifting weights for 35 years, and I got all kinds of injuries.
28th Mar 2023, 6:28 pm | #6 |
Be nice to get it going, just to see the indicator, I guess it would move up and down as the output waved about? Not sure I'd dare try it in person mind you in case that transformer insulation is past its best.
Kevin |
28th Mar 2023, 8:21 pm | #7 |
Location: Dalbeattie, Dumfries and Galloway, Scotland, UK.
Any date codes on anything (especially the capacitors) to give a date to this thing?
28th Mar 2023, 8:37 pm | #8 |
I was hoping to see something about the Medical stimulator to combat nervous 'tics' that was in the news recently.
'Life changing' Tourette's gadget trialled A bit of googling led me to the research paper detailing the procedure and results, from which we can see that bursts of 12Hz pulses at a defined repetition rate were used. They helpfully include details of the positioning of the gel pads, and the current amplitude needed seems to be marginally subliminal. I was thinking any Lab pulse generator with triggering and variable amplitude could be used. Entraining Movement-Related Brain Oscillations to Suppress Tics in Tourette Syndrome Think I'm developing a bit of that Tourettes
- Julian It's good here |
28th Mar 2023, 8:50 pm | #9 |
I've repaired a veterinary equivalent, made under the name "Transeva" and used for physiotherapy/chiropractory on horses and cattle.
It was transistor-based, but early and battery powered for safety in wet areas. The output was a sharp pulse causing quite a fast and hard muscle twitch. Circuitry was like a plain old inductance discharge ignition system. David
28th Mar 2023, 9:04 pm | #10 |
I'm sure it was one of the 'Doctor' comedy films where a wheelchair-bound man was trying to seduce his nurse and she was applying one of these things to his leg presumably to keep his muscles in tone until he could get back on his feet. The Doctor series of films were made by Rank AFAIK..and Stanley Cox was a subsidiary of Rank, so I wonder if it was some obscure product placement?
Kevin |
28th Mar 2023, 11:21 pm | #11 |
I have a muscle stimulator made by Multitone.It has 4 valves, 3x EF91 and a PL81 which I guess is part of an HT stabiliser.l mean to draw the circuit one day.Probably dates from the 50's.There is paperwork with it.In a wooden box,well made and heavy,there is a mains transformer and 2 large inductance blocks with tappings for the pulse rate and width.Les
29th Mar 2023, 2:27 am | #12 |
Above is a photo of my late father, taken in the 1950's in his physiotherapy treatment room (the front room of our house). The large console on the right of which only half is in view, is an electrotherapy machine. I am fairly sure it was made by Electro Medical Supplies, a company that still exists as EMS Physio Ltd. I emailed them a few years ago hoping to get a scan of a manual, or some contemporary marketing material about the machine, and I did get a nice reply, although nothing specifically about my dad's machine. A similar, but older model, probably pre-war, was featured on Antiques Roadshow. The recess in the centre of the console is covered by a glass door and behind it the mechanism that rhythmically surged the current. it consisted of a glass flask filled with saline solution and a motor and lever arrangement lowered and raised an electrode.
-- Graham. G3ZVT |
29th Mar 2023, 2:49 am | #13 |
The thing sticking out the side of the transformer looks like a single lam (or part of one) that can move into or out of a narrow airgap in the main core. A variable coupling/variable voltage feature at a guess?
29th Mar 2023, 9:52 am | #14 | ||
The Colvern pot might have a 2-letter code and/or there might be an etch date on the valve, to corroborate. Quote:
With my curator's hat on, I would be thinking that if the capacitors were sound and it could be operated without getting a soldering iron out, all well and good. But if any parts needed replacing, would what we could learn from operating it justify the intervention in a unit that is probably in 100% undisturbed, as-built condition. OK, we see the DM70 light up and get tingles from it, but is that instructive? Last edited by Lucien Nunes; 29th Mar 2023 at 10:03 am. |
29th Mar 2023, 10:27 am | #15 |
Thanks for so many responses in less than 24 hours. In particular thanks for identifying the glass thingy as a magic eye. I am familiar with the larger diameter ones that you view end-on, having had one in my first tape recorder about 1958, but I hadn't met this kind.
I did suspect that the brown thing might be a coil somehow loosely coupled to the mains transformer, but it seems a very odd arrangement and I don't understand how it might work or why they would have chosen it. Anyone feel inclined to give the beast a home? |
29th Mar 2023, 10:47 am | #16 |
29th Mar 2023, 5:12 pm | #17 |
My stimulator is the type known as a Ritchie-Sneath,dated c.1952.The cost was £140.00 which would have bought you a top of the range console televisor.Les
30th Mar 2023, 10:02 pm | #18 |
By the way: These cute DM70 and DM71 valves need to be handled taking some good caution. The wires are easily broken and the heater takes not more than 25 mA @ 1.4 V!
Joe |
2nd Apr 2023, 8:53 pm | #19 |
Years ago I ordered a muscle toner from John Lewis (one of those multi channel things) and just had to lift the lid to see how it worked. It had a mains transformer to take it down to 6V and then a row of 'output transformers' and an oscillator to generate very narrow high voltage spikes (around 60-70V, I scoped them) for the pads. I assume this is a similar approach to the Stanley Cox model as it is able to generate muscle contraction without pain. I believe this is because the muscles react to the specific waveform but the nerves don't relay any pain. Just as well really.
Kevin |
2nd Apr 2023, 9:03 pm | #20 |
These aren't complete snake oil. Physiotherapists use their modern descendents to help people rebuild muscle tone after a traumatic injury. Obviously you do have to be wary of devices offered outside the mainstream health systrm though.
