23rd May 2022, 1:31 pm | #1 |
HRO power supply to power a R1155
Hi all, After fitting a mains transformer to the HRO power supply as the original fried its working fine can the supply be used to power a R1155 which a bought this weekend cheers Chris.
23rd May 2022, 1:42 pm | #2 |
Re: HRO power supply to power a R1155
The heaters on the 1155 are wired in a series / parallel arrangement, so you'd have to rewire it for 6.3v.
There's also a requirement for a negative bias supply, not sure if that is available from an HRO psu.
Regards Pete |
23rd May 2022, 2:06 pm | #3 | |
Lawrence. Last edited by ms660; 23rd May 2022 at 2:14 pm. Reason: grammer |
23rd May 2022, 2:30 pm | #4 |
Hi Thanks for your replies I am aware the the HT- in the HRO supply is direct to ground but with the R1155 the HT- it isn't .
23rd May 2022, 4:09 pm | #5 |
Just to add a 6V6 has been added with a output transformer so I need a supply just supplying HT and LT .
23rd May 2022, 4:40 pm | #6 |
So apart from the HT grounding issue, the HRO has a lower heater requirement but higher HT voltage.
My data suggests HRO uses 240V 70mA HT and 3.4V LT R1155 (with all valves) uses 217V 110mA HT and 4.7A LT So not a great match. |
23rd May 2022, 9:37 pm | #7 |
We need more information on the R1155.
Have the DF valves been removed and a 6V6 valve added added? Can you measure the new HT current? |
23rd May 2022, 9:48 pm | #8 |
Hi the DF valves have been removed and a 6V6 fitted to one of the sockets. I can't measure the HT current as i have no suitable power supply .
23rd May 2022, 9:49 pm | #9 | |
Cheers - Martin ZL2MC |
24th May 2022, 8:15 am | #10 |
Removing the DF valves saves around 1 amp of heater power apparently.
24th May 2022, 10:34 am | #11 |
24th May 2022, 11:33 am | #12 |
I'm afraid I don't agree with either of these statements. All the R1155s I've come across work with 6.3V AC on the heaters. Also there is no requirement for a negative bias supply - it is self generated by not grounding the HT negative.
24th May 2022, 11:47 am | #13 |
Interesting Keith I powered up the heaters on the 1155 yesterday from the HRO supply 6.3v ac and all glowed . But the HT from the HRO supply is still no good I take it.
24th May 2022, 12:02 pm | #14 |
24th May 2022, 12:04 pm | #15 |
If the HRO PSU produces somewhere around 220V HT it will be fine but only if you can isolate its negative rail from ground (RX chassis).
24th May 2022, 12:18 pm | #16 |
24th May 2022, 12:19 pm | #17 |
Understood Keith thanks for the info.
24th May 2022, 12:21 pm | #18 | |
Lawrence. |
24th May 2022, 12:25 pm | #19 |
Got it thanks Lawrence.
25th May 2022, 2:18 pm | #20 |
How can you isolate the negative rail from ground to use it for the 1155 . I read somewhere that someone used the HRO supply and used a switch to use it with a 1155 but I can't find where I read it.
