21st Aug 2020, 7:49 pm | #1 |
Transceiver's performance worse after changing electrolytic capacitors. Is it me?
I have a 40 odd year old vhf ssb transceiver and decided to remove and test a couple of electrolytic capacitors with an esr meter after noticing a dried substance near the offending items.
It was quite a job replacing all of the electrolytic caps due to the component density (some have been replaced with higher voltage as it was all I had). Sensitivity now seems to be worse than before the replacements? |
21st Aug 2020, 8:01 pm | #2 |
Re: It it me?
It should not effect performance ,unless you have a wrong value in or wrong polarity.Worth a double check.
21st Aug 2020, 8:17 pm | #3 |
Re: It it me?
Always the "other side of the coin" with mass re-capping is that you leave a bad joint or a bit of solder between tracks.
B
24th Aug 2020, 8:42 pm | #4 |
Re: It it me?
Double check the polarity of all the caps you replaced. On modern radial electrolytic caps the negative wire is the one that is normally marked.
Mike |
24th Aug 2020, 9:08 pm | #5 |
Re: It it me?
..and not completely unknown for the odd electrolytic cap to creep through quality control with the polarity labelling reversed.
24th Aug 2020, 9:29 pm | #6 | |
Re: It it me?
24th Aug 2020, 9:46 pm | #7 |
Re: Transceiver's performance worse after changing electrolytic capacitors. It it me?
Check that you've got all the screening covers properly refitted: at VHF these can be rather important.
[as an example: the Pye Westminster transmitter has a PA screening-cover made from a piece of PCB with some etching in the copper to break it up into controlled areas. Replacing a 'lost/missing' cover with a piece of plain, unetched PCB reduces the output-power by about 5dB) |
24th Aug 2020, 10:26 pm | #8 |
Re: Transceiver's performance worse after changing electrolytic capacitors. Is it me?
Just to be clear on marking, they do seem to like to mark the negative on the can, but I notice that the long wire is still the positive - which was the other way it is marked (but with the snag that you loose this info after assembly)
25th Aug 2020, 12:21 am | #9 |
It's also worth checking for any internal coax connections which may have come adrift. Those mini coax 'push in' types favoured by Yaesu have a habit of working loose during a service.
Andy G1HBE. |
