11th Mar 2020, 6:07 pm | #1 |
Philips N4418 wrong speed
Anyone having problems with speed adjustments? one can adjust the speed But the are all too fast!
11th Mar 2020, 10:06 pm | #2 |
Re: Philips N4418 wrong speed
I am not familiar with this model. A quick look at the Service manual indicates that all 3 speeds can be adjusted by the relevant potentiometer/trimming resistor.
If speeds cannot be trimmed down sufficiently, then can only assume that problem may lie with the Capstan motor/Impulse head and/or the associated Speed Control Unit. |
12th Mar 2020, 12:35 pm | #3 |
Ok thanks I have to check the speed control unit again difficult to find any faults when its working but too fast. A potentiometer in series to the motor will slow down the speed but that way the speed is not stable
12th Mar 2020, 9:02 pm | #4 |
Check the impulse head. Basically it uses a magnetic ring driven by the motor which sends pulses to the head (hence impulse head). These are fed back to the control circuit so they form part of a control loop. After all these years it's entirely possible that the magnet has become weak.
13th Mar 2020, 5:37 pm | #5 |
if so how to solve that how to know if it´s too weak?
13th Mar 2020, 7:32 pm | #6 |
You need to look at the circuit...that gives a waveform which you would then check with an oscilloscope....that's how we did it at Philips 30 years ago. Don't know how you would check it without a 'scope.
Check head for continuity first.
13th Mar 2020, 8:15 pm | #7 |
Thanks no problems I do have a Scope but can´t see a pulse info anyware in the schematics? I know I have a pulse
13th Mar 2020, 10:10 pm | #8 |
Hmmmm it's 30 or more years ago. We may have had more information available than just what was in the manual. I know there was a separate Circuit Description...maybe that showed the waveform. If you have pulses then it shows that the head and probably the rotating magnet is good. You need to check the feedback circuit.
14th Mar 2020, 4:31 pm | #9 |
Solved!
Solved thank you all. The pulse from the head was only 20mV and the reason the wheel on the motorshaft with the magnetic ring was not in line with pickup head mounted a bit off on the motor shaft. Happy Days! |
14th Mar 2020, 11:53 pm | #10 |
Yes I am also struggling to see the head pulse info in the schematics.
15th Mar 2020, 11:55 pm | #11 |
....You just triggered my memory ref the low pulse fault....it was always one of the first things we checked.....a note from Eindhoven was sent to the service workshops advising us to check that the rotating magnet was in line with the head poles. It's quite possible that we measured the pulse ourselves and wrote it in the manual....it's a very long time ago. There was a separate publication called the Circuit Description which, as the title implies, explained how it all worked. Possibly THAT had the pulse waveform shown.
16th Mar 2020, 10:38 am | #12 |
That is great news, what level of pulse voltage improvement did you obtain with better alignment ?
19th Mar 2020, 6:43 pm | #13 |
Around 400 mVolt
