3rd Jan 2015, 12:21 am | #1 |
An interesting write-up on half-wave aerials.
This may have appeared on this forum before - but it is the first time I've read it anywhere.
http://www.qsl.net/arrlsb/Digest/Pag...ntennas03.html Many a provocative thought in this - quite likely to generate a few comments. Nevertheless, a good read - but not to be read if you only have limited time - it's quite detailed and thorough. Al. / Jan. 2 |
3rd Jan 2015, 4:30 am | #2 |
Re: An interesting write-up on half-wave aerials.
Worth reading, as although it starts off on "Half Wave Antennas", it actually goes on to cover a diverse range of subjects about the downstream world after the Tx. I'm surprised by the claim that 70% of us reject the idea of using an ATU; surely not true ?
B
3rd Jan 2015, 11:49 am | #3 | |
But to summarise: what I drew, in conclusion from that article, was that the old school of "put up a convenient length of wire, as long and as high as you can get it, couple it to your TX with a pi-coupler (or any variation of a Z-matching device), and off you go", is as valid now as then. Al. |
3rd Jan 2015, 1:26 pm | #4 |
Exactly Al. My doublet with 450 ohm feeder along with a Z Match does the job reccomended in the article's conclusion,
I have done quite a few receive comparisons with instant switch-over from doublet to inverted L. (Strength, not s/noise ratio) The inv L signals are usually strongest. Theeoretically on 20m the doublet has 4 lobes of maximum at each quadrant that should be best for USA for example, but the Inv L still seems best. I have been planning on a simpler tuner than the Z match just in case its inefficient. 73 HNY Andrew |
3rd Jan 2015, 1:49 pm | #5 |
For my transmit antenna I have a 10m vertical with an SGC autotuner at the base, lots of earth rods too. Works a treat.
3rd Jan 2015, 2:05 pm | #6 | |
B |
3rd Jan 2015, 2:44 pm | #7 |
An interesting article - but he misses the essential difference between an antenna *tuner* and an antenna *matcher*.
An antenna tuner brings an antenna to resonance by adding L or C or some combination of the above to the radiating elements. The aim is that by bringing the antenna to resonance it presents an ideal, resistive impedance to the feeder. An antenna matcher is attached to an antenna/feeder which presents a complex impedance at the operating frequency, and uses L/C/transformer-action to con the attached transceiver into thinking it is working into a non-reactive load. It doesn't actually change the resonant frequency of the antenna. To my way of thinking - a tuner is directly-attached to the antenna and directly alters the antenna's resonant characteristics. The "Screwdriver" type mobile antenna is a good example of this, similarly the remotely controlled motor-driven high-voltage-capacitor used with transmitting loops. A matcher sits at the transmitter-end of the feeder. Me? I'm currently using a 10-metre dipole (which is resonant at 28.3MHz according to my GDO) and for the LF bands a 100.mumble-foot longwire with a Redifon roller-coaster which adds series-inductance. In the latter case I consider it as a tuner because I seek resonance with the GDO then switch to transmit. |
3rd Jan 2015, 2:54 pm | #8 | |
However, having said all that, in a few days time, I will be leaving this location for ever. Fortunately, the new home affords much more real estate and high points for aerial experimentation - so it's back to the drawing board. A balanced doublet is favoured, since the shack will be in an upstairs room, but there will be problems arranging for a balanced feed-line to leave that aerial at the appropriate angle (90° ideally) on account of the orientation of the garden and the house and also to enter the shack without seriously twisting the feed-line to an undesirable extent. But all that as may be: spring is on its way - well-known as 'antenna time' - fun should be assured!! Al. / Jan. 3, '15 // |
3rd Jan 2015, 3:15 pm | #9 |
4th Jan 2015, 6:37 pm | #10 | |
You can lose the artificial distinction between an antenna 'tuner' and an antenna 'matcher' simply by shrinking the transmission line to zero (or using an ideal lossless one). You then have two things which "essentially" different, yet they are the same thing. Two essentially different things cannot be continuously transformed into each other. Alternatively, put the matching/tuning in the middle of the line. What "essentially" changes as you vary its position from one end to the other? |
5th Jan 2015, 12:22 am | #11 | |
So, am I missing something in that line of thought? Al. |
6th Jan 2015, 12:32 pm | #12 |
Nothing fundamentally/essentially changes. Obviously you will want to present the correct load to a feeder (unless you are deliberately exploiting feeder impedance effects, such as a G5RV). A matching device at the antenna end does not change the antenna, unless you redefine the word "antenna" to include the matching device too.
To feed a 73R antenna from a transmitter which expects to see a 50R load you can use a matcher at the antenna end and a 50R cable, or a matcher at the transmitter end and a 73R cable. There is no fundamental difference between these. You could even use a mixture of the two setups: 73R cable to matcher then 50R cable to transmittter. The real issue is about reactive matching. Some people think adding, say, extra lumped inductance at an antenna feedpoint "tunes" the antenna. Others know that it is simply compensating for excessive capacitive reactance at the feed point. What we call it doesn't matter too much as the equations are the same. Problems arise when people attach too much meaning to a loose description or try to argue that two essentially identical situations are somehow fundamentally different. |
6th Jan 2015, 1:31 pm | #13 |
Yes, a good article although I think he didn't dwell so much on the main problem with funny bits of wire as aerials, which is that you can get rather strange radiation patterns. He also didn't perhaps warn that massive standing waves can result in a ball of plasma appearing where you didn't want it.
I use a random bit of wire and a big tuner. My setup is not very efficient, but only because it is much too near to the ground - although this does simplify the radiation pattern as it all goes straight upwards. I also have a device that hardly any hams seem to use - a balance meter. By the way, a couple of my definitions for you: "Aerial" is the bit of wire that looks like it does the radiating. "Antenna" is the bits of wire, ground, your house, your body, etc. that actually does the radiating. |
6th Jan 2015, 2:05 pm | #14 |
A matcher does not need to be resonant or frequency-selective: a 4:1 ferrite-core transformer used at the feedpoint of a folded dipole will transform the impedance to 75-ohms - ideal for feeding by low-impedance feeder (which can be coax or balanced-twin).. It does not affect the resonant frequency of the antenna so it is not a 'tuner'.
Same goes for things like delta- or gamma-matches on dipoles. [note: a transformer at the dipole feedpoint is not necessarily a 'balun' either!] |
6th Jan 2015, 2:06 pm | #15 |
My favourite one is "Power Supply: A broadband matching device that optimally couples RF energy on the mains to just where it is least wanted in a receiver".
6th Jan 2015, 5:09 pm | #16 | |
6th Jan 2015, 6:35 pm | #17 |
I forgot another important definition:
"Earth" - a mythical entity with large cult following in the ham community where many believe that it exists in their gardens or even in their water pipes. |
6th Jan 2015, 8:54 pm | #18 | |
Al. |
7th Jan 2015, 2:07 pm | #19 |
I think GMB was being both helpful and amusing. 'Official' definitions may differ from his.
7th Jan 2015, 7:12 pm | #20 |
Yes
All quite interesting but like all beliefs re antennas the replies are full of differing opinions but the laws of physics cannot be changed. It is a subject that will live on mostly due to the fact that the same antenna will give differing results depending on location etc. The main problem is that there is no such thing as an “antenna tuner" just does not exist. The device provides capacitance and or inductance to match the feeder to the rig and just fools the rig into seeing a “tuned antenna" The only method of correctly “tuning an Antenna" is by getting the element lengths correct for the band required, most people would not go wrong with creating a correctly cut fan dipole, cheap and very effective. Claims for an all band low SWR antenna should be viewed with suspicion; these can only work with the addition of a matching unit “now wrongly called an antenna tuner” MM0HDW (QRZ.COM) |
