9th May 2009, 2:39 pm | #441 |
Re: AVO Multimeter survey
Just picked up AVO 8 12357-C-353 from the car boot and although it's (slightly) older than me it still works fine although missing its leads unfortunately. A 1953 original so that's 6000 a year or so I guess.
29th May 2009, 2:30 am | #442 |
Sorry, I've been out of circulation for a few weeks.
Thanks for the input, but you're underestimating the production rate: it was nearer to 9,000 for 1953 ! And ALL hand calibrated on TEN cardinal points ! (I'll resist the temptation to evangelise) |
6th Jun 2009, 9:15 am | #443 |
Hi,I have an 8 MK111 No 70475.1167
and an 8 MKV No 0033898 CC 8V Paul |
19th Jun 2009, 2:05 pm | #444 |
Hi - I've got an ex-works (scrapped!) AVO Model 7 MkII, Serial number 46955 A 454.
Cheers, Neil |
21st Jun 2009, 12:34 pm | #445 |
Hi, two more for the collection (assuming you don't already have them - I've just acquired them and don't know their history):
AVO 7 71042-8654 AVO 8 167823-C-364 I don't know what Mk Nos they are so I've attached some pics. I imagine there is nothing special about them, but if there is I'd be interested to know. Am I right in thinking they are 1954 and 1964 respectively ? Cheers, GJ |
21st Jun 2009, 3:19 pm | #446 |
Thanks for the input.
First off, they're ALL special, but let that pass (OK, I'm a freak). As you suggest, the Model 8 is from 1964, and is one of the last: it's from March, and the Mark III took over from June of that year. The Model 7 is much older, and uses an earlier numbering scheme: it's from October 1942 (before I was born, and probably in better 'nick' than I am !). Treat them with care. If you can check the calibration on the Model 7, I'd be interested to hear the result by PM. |
24th Jun 2009, 10:15 pm | #447 |
My Model 9 mk2 has the following s/n; 16154.1168
Calibration is spot on even after 40+ years. Only trouble I've had was with the cam contacts which someone had tried to "adjust" in situ. Totally stripped down the meter and contacts, only to find the original fault once reassembled. The cam had either worn or lost its timing, I'm surprised the cam isn't keyed to the shaft. All ok now though, have genuine 0-30KV probe to go with it too. A pleasure to use, and easy to repair.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
25th Jun 2009, 10:43 pm | #448 |
Yes, they're virtually indestructible,
and the Model 9 Mk II came at the end of the "great era". Cherish her - like ships, they're all female, and have individual personalities. (I would advise you to sniff her [respectfully], but might get booted off by the Moderators !) |
3rd Jul 2009, 12:57 pm | #449 |
I have an 8X Panclimatic Model, steel Hammerited shroud with green fabric/plastic carrying case. Bought from an Autojumble, great condition.
No 70974-C-258. A.P.12945A Regards, Sean. |
13th Jul 2009, 11:42 am | #450 |
Hi spch heres my avos
dc avominor 8140-14 (jan 1934) 15130-54 (may 1934) d.c. avominor TYPE H.R. 206-108 (oct 1938) avominor TYPE E E21264-1945 universal avominor 54320-143 113542-751 model 1A 2692-157 model 1A3406-257 model 2 3195-1254 model 2 7436-1256 D.C. avometer 13range (model 2) 4292 22range (model 6) 6394 universal avometer 36range (model 5) 114-3190 (nov 19340) british rail avometer 957-1249 die cast ali type model D 20797-645 universal avomrter TYPE H.R.2026-450 model 1 model 8 Mk7 1011 M566270-1190 model 9 Mk2 1189-1165 model 12 2678-468 model 16 11019-v-271 model 47A 13488-144 model 48A 10680-143 model EA113 5866-6c31-776 regards Mike |
25th Jul 2009, 2:19 am | #451 |
Hi
Here are mine EA 113 5365 Avometer 8 05470 8V/11/78 James |
30th Jul 2009, 9:21 am | #452 |
Hi, as a new member who discovered this forum whilst looking for avo info i thought i had better do my bit.
I have a model 7 mkII serial No 76519-A-658, this one came out of a skip at the local regional college !. My other one is a model 8 mkIV serial No 33060 84/2/71, it says avo ltd dover on the label. This was purchased last weekend from a car boot sale for £8, not sure if it works yet as it has no batterys in it. Gerry. |
2nd Aug 2009, 1:22 am | #453 |
Have several AVOs and will dig out serials.
The one on my desk may be a bit of an oddity:- Model 7 MK2 serial No:-49460-A-954 Its in a normal black case but the Front is BROWN. Brown switch selectors.Brown terminal screws .Normal white meter part no : 10945-19 May have got it originally when AVO donated bits to the Radio Club that I was involved in , when at school. Would have been in about 1959-60 ish. Anyone any ideas? Regards Nick |
3rd Aug 2009, 12:45 pm | #454 |
Nick,
Brown phenolic mouldings, as you describe for the front panel and knobs of your Model 7, are characteristic of panclimatic Avometers. Panclimatic models are designed for use in extreme climates including tropical conditions of high temperature and humidity. The brown moulding is a modified version of phenolic resin which resists mould growth. Avometers designed for these conditions were available from the late 1940s in response to experience of using electronic equipment in the Far-east during the Second world war. Some early panclimatic Model 8 meters are a milk-chocolate colour with a reddish tinge which becomes quite marked in some lighting conditions. If you ever hear of a "red" Avometer, it is probably one of these. If your meter is a genuine panclimatic model, many of the internal components will be encapsulated in epxoy resin, also to counteract mould growth. As late as 1954, there were still post-war material shortages, so that some meters may possibly have been built up with available mouldings even if they were not to full panclimatic specification. PMM. |
3rd Aug 2009, 9:32 pm | #455 |
Add to the collection the next in my collection:
A Universal AVO Minor Serial number not obvious on the meter but the case has No.U40365-241 Ah, faceplate serial no. is U40365-241 so they are the same. This one belonged to a Captain in the Royal Signals if you are interested. The glass is loose so I have put a 'help' request in the forum. James Last edited by jamesinnewcastl; 3rd Aug 2009 at 9:56 pm. |
9th Aug 2009, 4:19 pm | #456 |
I have another AVO 9 which was an ex-RAF instrument. It has serial number 10,011 - 1170, so I assume it was manufactured in November 1970. It is in good working condition, has a burgundy tinted bakerlite facia and metal case. It is slightly larger than my military AVO 8 Mark 6 and quite a bit heavier.
Neil.
An engineer makes for a penny what a scientist makes for a pound! |
9th Aug 2009, 7:21 pm | #457 |
Aquired today at the FRARS Hamfest:
Avo 47A S.No, 401361-942 And, Avo 7X panclimatic. I'm not sure about the serial number. It isnt in the usual place, on the scale near the bottom of the glass. On the case at top centre it has 6625-99-943-1531 On the side of the case is a stick-on label, AVO Ltd, Serial No. 20140 7X/11/70 (There is also a partially erased label that originally said ASWE-Admiralty Surface Weapons Establishment. I assume it came from Portsdown Hill.) Would the actual AVO serial number just be on an adhesive sticker? |
9th Aug 2009, 7:30 pm | #458 |
Yes, the serial nhumber is the one on the sticker. The number at the top of the case is a NATO Stock Number.
9th Aug 2009, 7:48 pm | #459 |
Alan,
That takes me back. I used to go to ASWE regularly, and AUWE as well, although it was nothing to do with weapons. I also went to SRDE, which was the real story Alan |
9th Aug 2009, 9:16 pm | #460 |
Hello.
My AVO is a modle 8xpanclmatic. Its number is 171247-c-565= May 1965 it has a Nato number on it 6625-99-9431532. EX (RAF) and working 100%. Regards Kev. |
