Old 30th Jul 2015, 7:46 pm   #1
G8BBZ
G8BBZ's Avatar
Default Redifon GR161B Fishphone
Hi All,
I have recently acquired one of these units and intend to get it going on 3615kHz AM. It has suffered some mechanical damage so I will need to partially dismantle to sort things out.
The rig seems to date from the early 60's and uses 2x 807 in the PA modulated by 2x 807. HT is generated by a transistor inverter. The receiver is all valve, except for the audio output which is transistor.
I am hoping someone will have some info on this little rig, even a circuit diagram. Also, Can anybody confirm that it works from 12v DC - it is not completely clear to me if the DC input is 12 or 24v DC.
Peter G8BBZ
Peter G8BBZ
G8BBZ is offline
Old 31st Jul 2015, 11:50 am   #2
Herald1360
Herald1360's Avatar
Default Re: Redifon GR161B Fishphone
Stick in 12V and see whether the heaters light up properly?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 2nd Aug 2015, 10:01 am   #3
gm0ekm cecil
Re the Redifon r/t GR161B, the input is 24 volts. I do have circuit diagrams for this set, I'll have to trawl through my library to locate them. I have the GR 161B on display among my museum collection on show to the public.
Cecil. ---GM0EKM.
gm0ekm cecil is offline
Old 3rd Aug 2015, 1:17 pm   #4
G8BBZ
G8BBZ's Avatar
Hi Cecil,
Many thanks for your input. I am keeping my fingers crossed you can find the circuit!
Yet another reason to visit your museum.
cheers
Peter G8BBZ
Peter G8BBZ
G8BBZ is offline
Old 4th Aug 2015, 11:03 am   #5
GW3OQK Andrew
GW3OQK Andrew's Avatar
Any chance of a picture of it? I cant see in on the internet, or remember it from when I worked for Redifon
Andrew
GW3OQK Andrew is offline
Old 4th Aug 2015, 10:02 pm   #6
gm0ekm cecil
The Redifon Type GR161B Radio Telephone.
I've still not unearthed the circuit diagram, bear with me I do have it.
Name:	73-Redifon - Radio Telephone type GR161B.jpg
Old 5th Aug 2015, 11:11 am   #7
G8BBZ
G8BBZ's Avatar
Thanks Cecil - good luck with the circuit diagram.
Hi Andrew,
I worked at Broomhill Road from '68-'71 and don't recall ever seeing this piece of equipment. I am suspicious that it may not have been manufactured at Broomhill Road - there are part numbers on some of the major components that don't look like Redifon part numbers of that era - so it may have been bought in as the later GR377 was (from KW)
It's a nice little rig and doesn't show signs of having had much use so I live in hope of getting it going on 3615kHz.
cheers
Peter G8BBZ.
Peter G8BBZ
G8BBZ is offline
Old 6th Aug 2015, 1:30 pm   #8
GW3OQK Andrew
Peter, I think I have tested it on a ship, and there is another example on the museum lightship in Swansea so I'll have a look next time there. I would have expected Redifon name plates screwed on the fronts, but perhaps it was on the cabinet, above the tx.
I joined Redifon marine service in about 1971, was based in South Wales, with occasional visits to Wandsworth. It was a busy time and that red brick building was full of people making I don't know what.
73, Andrew or Andy as I was known in the firm.
