Old 28th Jan 2015, 9:50 pm   #1
PWH
Default Yaesu FT757GX No AM/FM rx
HI I have just obtained one of these and disappointingly, It won't receive on AM or FM tuned to the MW broadcast band, or any other I can hear stations with SSB or CW wide or narrow mode, but on AM, there is just static as if no aerial is plugged in. FM hisses loudly, but of course, no FM stations on that band. I have check the protection bulb is intact.
There appears to be a fault on transmit too, (SSB works but no carrier am/fm) which I will save for another day but mention it in case it is related.
Any ideas where to start? Thanks
Peter G0PWH
PWH is offline
Old 28th Jan 2015, 10:15 pm   #2
_Clint_
Default Re: Yaesu FT757GX No AM/FM rx
There are some nice diagrams in this document showing signal paths, well worth a look at in your case: http://www.iw2nmx.it/Yaesu/FT-757GX/...e%20Manual.pdf
If it sparks, it was either meant to spark, or something is wrong, very very wrong.
_Clint_ is offline
Old 28th Jan 2015, 11:29 pm   #3
PWH
Thank you. I have this booklet, but unfortunately as per the online version the signal path drawings are nearly unreadable (to me anyway)
I have an RF sig gen, perhaps there are some test points where I can inject a signal??
PWH is offline
Old 29th Jan 2015, 5:36 am   #4
vu2nan-nandu
vu2nan-nandu's Avatar
Hi OM Peter,
The problem appears to be related to switching of the filters since both receive and transmit do not work on AM and FM modes.
You need to focus on the filter switching diodes.
Economy versions of FT-747GX were plagued with similar problems due to faulty plated-through-holes on the double-sided filter board. These were solved by wire interconnections at faulty PTH points. The same problem on PA boards resulted in 'no drive' to the final transistors.
Good luck!
73,
Nandu.
https://nandustips.blogspot.com
vu2nan-nandu is offline
Old 29th Jan 2015, 10:02 am   #5
HamishBoxer
HamishBoxer's Avatar
Wonder if it is some thing like dirty relays? Certainly common to rx/tx.
HamishBoxer is offline
Old 29th Jan 2015, 10:36 am   #6
Hermit6345
Hermit6345's Avatar
I assume that you have the Technical Supplement for the FT757GX? There are some alignment/level checks for FM in there both on RX and TX. Also check that the Drive control on the front panel is set fully clockwise, although that would only affect TX. Rigs of this age can suffer from Xtal failure. Ideally you will need an RF millivoltmeter and an AF generator. You should then be able to isolate the fault.GL.
Ian
Hermit6345 is offline
Old 29th Jan 2015, 10:59 am   #7
David G4EBT
David G4EBT's Avatar
Just a few thoughts:
Might be worth making sure that all the controls are correctly set (attenuator etc) before assuming that the rig is malfunctioning, but I assume that you’ve done that anyway.
I believe that the 757 has more than 450 semiconductors, many of which are diodes, which anecdotally, are said to be a known weakness (given the age of the rig).
Obviously you need to narrow it down - you can't crawl all over the rig checking every diode just in case.
If you are lucky, it could just be tarnished switch contacts from lack of use if the rig has been stored for some time.
You might wish to post the symptoms at the ‘Fox Tango’ group here:
http://www.foxtango.org/phpBB2/viewtopic.php?t=481
There’s quite a long list of topics at the MODS DK site (which you need to join to read/download):
http://www.mods.dk/index.php?ModelId=56
And here:
http://vss.pl/mods.dk/mods.php3-radi...lectid=all.htm
Also some ‘mods and fixes’ here:
http://www.normsweb.com/tektips/ft757.shtml
Best of luck with it Peter.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 29th Jan 2015, 6:23 pm   #8
PWH
Thanks for all the above info which I shall go through. The filter switching diodes sound promising. I would add that I have since noticed the internal "marker" tone can be heard on SSB but not AM/FM.
Yes I do have the technical supplement also linked above. Unfortunately I am not technical enough to understand it fully.
PWH is offline
Old 26th Feb 2015, 3:32 am   #9
PWH
Possibly. the xtal has failed. Is there any way to test it??
PWH is offline
Old 2nd Mar 2015, 2:43 am   #10
SiriusHardware
If you have a scanner receiver - ideally one with an S-meter, which is able to tune to the marked frequency on the crystal, try doing that.
When the crystal is running, you should see a strong indication if you take the tip of the scanner's aerial close to it. When you switch the set off or select a mode or setting which turns the crystal off, the signal should vanish.
The advantage of using a receiver to check a crystal is that it does not require a direct connection to the oscillator: That might detune or even stop the oscillator altogether.
SiriusHardware is offline
Old 6th Mar 2015, 2:31 am   #11
PWH
Thank you SiriusHardware, I'll give that a go.
PWH is offline
Old 18th Jul 2015, 7:03 am   #12
vu2nan-nandu
Hi OM Peter,
Problem solved?!
73,
Nandu.
